Old 12-30-2003, 09:58 AM
jpellegren jpellegren is offline
Angry 90' Accord High Idle
I'm having a problem with my 90' Accord. When I start the car it idles from 2,500 - 3,000 RPM. And when its warmed up, it still sits around 2,000 - 2,500. I can't figure out whats wrong with it. Really erkin' me
Thanks,
~Jake
Old 12-30-2003, 10:28 AM
mitcheal mitcheal is offline
Re: 90' Accord High Idle
i'd check for a vacuum leak, or maybe the throttle position sensor is bad? i'm not a mechanic, but that's what i'd check first... is it showing any codes?
Old 12-30-2003, 01:21 PM
BullShifter's Avatar
Re: Re: 90' Accord High Idle
Check for a vacuum leak, you should be able to hear it. Wiggle some hoses around with the engine running, that might help you find it. Has the idle been adjusted recently. Now there is a code, most likely it will be for the EACV.
If it's a hose, don't duct tape or half ass it. Get a new hose, please.
Welcome to AF
Old 01-01-2004, 12:29 AM
accordztech accordztech is offline
Send a message via AIM to accordztech
find the FPR...fuel pressure regulator and see if u see a vacumn line on one end of it.
if thats off then ur rpms will be as you said...
check ur throttle cable for proper deflection and for now lower ur idle with the idle adjustment screw on the throttle body, near that big red hose...its a flathead black screw...
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
