Old 12-30-2003, 04:51 AM
criticalbass criticalbass is offline
power window lift motor 84 full size blazer
"new" 84 blazer's tailgate window lift motor works for a little while, then stops. Allow time for cool-off, and it works a little more. I suspect the motor is near death and would like to replace it, along with the keyed switch which doesn't work at all.
I don't want to break any rules here--I'm a new member--and when I scanned the rules I didn't notice any problems with mentioning commercial sources, but some forums don't do it. So, If it's allowable, does anyone know of a source of either the motor or the switch. The motor is a special order item at the dealer, and runs in excess of $150.
This vehicle was a credit union repo and has lots of issues. The exhaust stopped under the driver's feet. It was a noisy drive home and to the muffler shop, but now that's taken care of. Front drive line spline is stripped out and condition of the other 4x4 components is still uncertain.
But right now I need that tailgate lift motor. Any advice would be welcome. After looking at a lot of recent posts I notice that very few involve blazers as old as my '84 are mentioned. Does anyone know if there are other forums which focus on the older full size blazers? Thanks. CB
Old 01-07-2004, 09:16 PM
update
$210 later, front drive line is replaced and other components seem to be working. Maybe I got lucky. Have found source of $75 (O'riley's) rebuilt lift motor, still shopping for more reasonable one. Any other folks with older blazers out there?
My tires are 31" tall. Can I go bigger without lifting? CB
Old 01-07-2004, 09:23 PM
modification_inc's Avatar
modification_inc modification_inc is offline
Send a message via MSN to modification_inc
Re: power window lift motor 84 full size blazer
Never hurts to give ebay a try. If its a full size blazer you should be able to fit 33s under it,
Old 01-11-2004, 11:35 AM
amysinsanity amysinsanity is offline
I have the same problem with my 84 K5. we found that its the switch on the dash not the motor. I had to replace the switch for my drivers side window switch and everyone ( the parts stores ) kept telling me I needed the whole engine. But we started small and didnt have to work to big.
Old 01-11-2004, 09:20 PM
jshadwick jshadwick is offline
try www.coloradok5.com
for anything Chevy Blazer
**they do have forums for your year of Chevy Blazer.
Old 01-22-2004, 11:22 PM
cjs_12345678 cjs_12345678 is offline
Send a message via Yahoo to cjs_12345678
the switch you can get at your local parts house try taking the motor out and cleaning the brushes with some fine steel wool
Old 01-22-2004, 11:24 PM
you can use upto a 91 motor
Old 03-12-2004, 02:20 PM
dumbplumber dumbplumber is offline
the other thing you can try is the gate switch may be dirty try cleaning the contacts on that. I had the same problems with my 83. that did the trick. As long as you don't have running boards on yours 33's fit very nicely. That is what is on mine!!
Old 04-18-2004, 08:48 AM
k-5_350 k-5_350 is offline
i ve got 33's on mine no lift no mods and no rubbs the look slick and damn thing never gets stuck.
Old 04-18-2004, 08:53 PM
AutoZone finally came up with the replacement motor. Works fine now. Still need to chase down the key switch problem and the non-functioning interlock which I have jumpered. (glass will lift with tailgate in any position right now.) CB
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
