Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-30-2003, 01:09 AM
JeffK69 JeffK69 is offline
Turbo specs...
Does anyone know, what is the Turbo/ Engine RPM ratio when Turbo is in "boost"....? Average???
Old 12-30-2003, 10:44 AM
454Casull 454Casull is offline
Re: Turbo specs...
You mean how long it takes for a turbo to spool up?
That depends on the turbocharger and the engine it's fitted to.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-30-2003, 02:15 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Exactly, that would depend on the engine and turbo combination. There are too many variables that can affect airflow that you could lengthen or shorten the time it takes for the turbo to spool. You could only get an average from a certain engine, exhaust, intake, turbo, and intercooler setup.
Old 12-31-2003, 04:12 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: Turbo specs...
also don't forget that the turbo's are load dependent too...if you pull a trailer uphill you'll see boost even at low rpm since you are spewing quite a bit of exaust under heavy loads
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 01-01-2004, 12:29 AM
Question Re: Re: Turbo specs...
O.K. Well I'll be more specific then. I am trying to fit a semi V-8 turbo to a Pontiac 455 (462) and I'm trying to find out how to set it up for the correct RPMs for the engine and turbo because it will be belt driven.....
Old 01-01-2004, 03:03 AM
Neutrino's Avatar
Yaya Master
Re: Re: Re: Turbo specs...
so you intend to take a turbo from a diesel 18 wheeler and transform it into a centrifugal supercharger?
(\__/)
Old 01-02-2004, 10:17 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: Turbo specs...
ummmmm, no.
I would asume that unless you HAVE to use that setup for some strange reason, you should not.
turbo's are meant to be runn off exhaust, not a belt.
Mustangs are nice, but I'd rather have one of these...
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
