Digital Cluster Swictheroo
What years and models cars digital clusters are interchangable with the 240sx ( specifically 1990 240sx SE )
Re: Digital Cluster Swictheroo
Are you trying to swap a digital cluster into a 240sx that already have one? If so, you have two ways that I can think you can do it. One way is to switch the whole gauge making sure that the cluster is the same engine type as the one you are swapping. Since 1989 to 1990 is SOHC and has a tac that redlines at 6, you can't use a gauge from 1991 to 1994 DOHC. The speedo will work but then the tac won't. Same if you swap it around. The other way is to take the part from the gauge, meaning if you ahve a broken speedo, you can take the speedo from any 240sx digital gauge and swap it. Just make sure your tac is the same as your engine type. 1989 to 1990 get a tac with a redline at 6. 1991 to 1994 get a tac with a redline of 7. Hope this helps.
where can I get digital gauges?
ebay?
Qualified Automotive Engineer
try a junk yard or car-parts.com i believe.
