Old 12-29-2003, 10:04 PM
scott_xrx scott_xrx is offline
crankshaft sensor
I'm trying to replace the crankshaft sensor on 1995 supercharged 3800 is the bolt nomal or reverse thread on the end of the shaft, how do I keep the shaft from turning, anything else I should know?
Old 12-31-2003, 09:20 AM
agrant6 agrant6 is offline
It's a normal lefty loosy and the only way to get the crank pully bolt off is with an air impact and 15/16 socket. There is a service window on the flywheel gear ring. I used a flat tip screwdriver on the gear ring to prevent the engine from turning. Again a air impact is necessary.
