Old 12-29-2003, 08:11 PM
jonfitz jonfitz is offline
Question keyless remote programming for 95 leSabre
Can anyone help me out with programming instructions for a 95 LeSabre keyless entry remote.
Old 01-15-2004, 08:34 PM
tdenkler tdenkler is offline
Re: keyless remote programming for 95 leSabre
efore entering the programming mode, verify the possession of all of the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases. The other transmitters will not be functional until you program the transmitters again. You may program up to 4 transmitters.
Perform the following procedure or use a scan tool when adding new transmitters or replacing failed transmitters:
1 Turn OFF the ignition switch.
2 Use a fused jumper wire in order to connect the data link connector terminal 8 (BLK/WHT) to terminal 4 (BLK).
3 Close all of the doors.
4 Turn ON the ignition switch. The door will cycle to lock.
5 Press and hold the following buttons on one of the transmitters for 30 second:
LOCK
UNLOCK
After a 30 second delay, the doors will lock and unlock.
Important
Do not turn OFF the ignition. If the switch is turned OFF, the first transmitter becomes inoperative.
In order to program extra transmitters, repeat Step 5.
Disconnect the fused jumper wire from the data link connector (DLC).
Use the same pic of the connector from the above post.
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 1 08-25-2010 06:06 PM
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 09:13 AM
Keyless remote programming for Highlander fmwaz Highlander/Highlander Hybrid/Kluger 14 07-08-2006 12:18 AM
Keyless remote Programming for Pontiac GrandAM wngriff General Discussion 0 12-05-2003 10:05 PM
Keyless Remote Programming for 03 Camry? bwhite1240 Camry/Camry Hybrid/Vista 0 10-31-2003 05:17 PM
