Go Back   Automotive Forums Car Chat > BMW > Z3
Old 12-29-2003, 06:03 PM
bmwmroadster bmwmroadster is offline
98 MRoadster Questions
Hello everyone. I'm new to both this forum & BMW, as I just purchased a 98 MRoadster. I do have a couple of questions I need help with:
1) Is the dealership the best place to purchase an owner's manual? (The previous owner lost it)
2) The driver's side seat belt clip (located on the seat itself) broke & I have a replacement for it. However, it appears that the only way to repair it is to remove the outer leather, fit the new piece, & reupholster the seat. There's has to be an easier way, correct?
3) The clock located next to the volt meter & oil pressure gauge does not illuminate. I have a replacement bulb, but wanted to know the best method of removing various pieces to fix it.
4) When the vehicle is initially turned on, I see, under the speedo & tach, an oil pressure meter. If I'm reading this correct, the further in the red the meter reads indicates the need for an oil change, correct?
Thanks to anyone that could help me with these issues.
Old 05-19-2004, 06:15 PM
crash8168's Avatar
crash8168 crash8168 is offline
Re: 98 MRoadster Questions
The seat cover peels off the seat to change the belt holder. Move the seat forward, go to the rear of seat, unclip from bottom, roll open the joint in the back slide the panel down and remove, remove the leather from metal frame. at this point you can change the belt holder.correct assumption with the service lights.
Old 06-25-2004, 11:26 AM
Ricka220 Ricka220 is offline
Just be careful to keep the rubbery side under you. I know of three guys who have pushed it ajust a little bit much.
Check out my wooden cars at woodensail.com
Old 11-16-2008, 05:33 PM
ggabriel ggabriel is offline
One more question, how do you change the bulbs on the heater control panel? I see the power wires but no bulbs are obvious. I have almost everything off so any help is appreciated. Thanks!!
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
What is replacing the MRoadster tomzdon Z3 7 01-31-2003 06:19 AM
