Old 12-29-2003, 05:01 PM
blueboost's Avatar
blueboost blueboost is offline
paint removal with plastic, putty, AND resin?
I can't seem to find the answer I'm looking for on this. I'm sure some of you can help me.
now I know to strip paint with CSC or brake fluid. cool, but thats on a basic plastic car model body.
lets say I add a SAS resin kit to the model, and also I use putty to shave doors and make fenders more flared. Now, instead of just having a plastic model to soak, I also have a resin bodykit and putty all over the model. can I still soak the model or will it ruin the resin and putty? do I have to go about removing the paint in another manner? if so what do you suggest? thanks for the help!!
Old 12-29-2003, 05:17 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
CSC will react differently to various putties and may or may not remove it. However I do know never no NEVER EVER put resin in CSC unless you want to go buy a new one. CSC will absolutely destroy resin parts.
Instead I recommend the brake fluid method.
Good Question!!!!!
Old 12-29-2003, 06:54 PM
blueboost's Avatar
Re: paint removal with plastic, putty, AND resin?
thanks dag!!
so no CSC for modified models with resin parts.
I figure besides the plastic model body, there is still other parts left to melt on many of my models like:
-resin bodykit
-putty
-styrene
-the glue holding it all together
if I build a model containing all of these things how can I strip the paint if I do a poor job???
this is why my S15 silvia had a sub-par paintjob.. because I thought it was a one shot deal, mess the paint and goodbye to a very expensive and time consuming project.
I really hope I can get some more of everyones thoughts on this.
Old 12-29-2003, 07:22 PM
snk33y
Guest
Posts: n/a
By far the best paint stripper that i have ever used is Easy Lift Off made by a company called Poly S, its not harsh on plastic, im still yet to loose a kit over it, it only took me half an hour to completely strip my GT4 back to bare plastic. only draw back is that its nasty on the lungs and fingers make sure you wear gloves and a respirator.
Old 12-30-2003, 12:39 PM
blueboost's Avatar
OK thanks snk33y.
no one is answering my question specifically. I know many ways to strip paint off of a model. please re-read my last post. I need help here guys, I'm at an impass until someone helps.
Old 12-30-2003, 12:59 PM
dag65's Avatar
Re: Re: paint removal with plastic, putty, AND resin?
Originally Posted by blueboost
OK thanks snk33y.
Re read my post, use brake fluid, soak it over night
Old 12-30-2003, 02:38 PM
blueboost's Avatar
Good Question!!!!!
OK dag65, theres your first post, which I appreciate
I just want to know will brake fluid method possibly eat away at the resin, styrene, putty, or even the model glue holding it all together??
am I 110% safe here? is this a guess? have you tried it?
no guesswork on this next model. I want to give it everything I've got.
Old 12-30-2003, 02:55 PM
dag65's Avatar
I have used brake fluid and it works well, to my knowledge it won't bother anything. However all putties are different. Easy Off oven cleaner works well also.
Heres a suggestion, take some of your putty and make a ball and let it dry. Put it in whateve stripper you are using and see what happens, then you know for sure and nothing gets harmed
Glues may become brittle but thats the chance you take.
Good luck
Old 12-30-2003, 03:09 PM
blueboost's Avatar
thanks for your help and patience dag. It's truly appreciated.
Old 12-30-2003, 03:43 PM
flyonthewall's Avatar
Car Mod guy
Brake fluid works fine for stripping resin...well...at least the resin used in my t/kits. I had heard previously that it will dissolve resin but that was proved wrong the first time i stripped one of my kits. I have not stripped any other resin so couldn't possibly give a well informed comment but i can't imagine there will be any problems.
You may also find that you will need to redo all your putty work as the brake fluid will often effect that.
Old 12-30-2003, 05:15 PM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
Further to FOTW's post, I have put a Renaissance resin transkit in brake fluid before and it did not have any adverse affect on it. The brake fluid I used was some cheap Dot 4 stuff.
engine paint removal or other parts from plastic Toolman56 Car Modeling 5 12-08-2010 12:43 PM
Lower Radiator Hose Removal, with Transmission Cooler lines blazerchase S-10 1 08-29-2010 03:56 PM
How Can I Paint Again A Plastic Model That I Paint With A Brush? pollapellos Car Modeling 5 03-02-2006 12:29 PM
Paint removing with nail polish remover Digitor Car Modeling 10 12-16-2005 08:48 AM
Paint removal on clear plastic? sr20ser Car Modeling 7 05-24-2004 12:38 AM
