Old 12-29-2003, 03:40 PM
Crashz Crashz is offline
Question Amp + Sub in Jetta Question
Hi everyone, new to the board here. I do have a question in mind though. I am in no way shape or form knowledgeable in car audio. I have an amp and sub in my possession and I recently purchased a new vehicle (Jetta 2003 1.8T). The amp and sub were left over from an insurance cover. What information I am after is whether or not it is possible to install this amp and sub into the factory deck of the Jetta. Again I am in unfamiliar territory so any help would be appreciated in this matter. My e-mail is [email protected] if you would prefer to contact me directly, which would be the easier way for me. Thanks in advance for any input you may have.
Old 12-29-2003, 04:28 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
Re: Amp + Sub in Jetta Question
I soldered female RCAs onto the output of my factory headunit. All you need is a wiring diagram to figure out which wires are which channel. You will probably need a ground loop isolator from radio shack to keep out the noise (I am too lazy to put mine in). This method won't sound killer but it is a stealthy way to upgrade one's stereo
Old 12-29-2003, 04:49 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Amp + Sub in Jetta Question
are you serious?
If you want to add an amp to a stock system do it the right way and use a line output convertor
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-29-2003, 05:02 PM
How hard is that to do with the line output converter? Would a shop be able to do something like that? Once that is installed, the amp and sub can be installed into the factory deck then? Sorry for all of the inquiries, but again, I am pretty much in the dark with all of this. Thanks for the input!
Old 12-29-2003, 09:41 PM
sr20de4evr's Avatar
very easy, you just splice the speaker outputs into the wires on one end of the LOC, and then plug your rcas into the other end of the LOC. This is what all shops use when they install an amp into a factory system.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-30-2003, 09:36 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it's about as easy as ToyTundra's method .... and works a LOT better
Old 01-02-2004, 05:29 PM
ToyTundra's Avatar
I forgot to mention that the Tundra comes with a poser factory amp so i am dealing with pre-amp outs (kinda). That is why i cant tell the difference with or without a LOC in my case.
Old 11-30-2004, 08:22 PM
[email protected] bulk@hatzakis.net is offline
I bought them from "PartsExpress.com". It's a little blue thing the side of a tube of toothpast, you cut your speaker wires and this will serve as a level converter (it just brings the signal strength down). They are a peice of cake to use. You can get to the wires at the speakers. My dealer fax'd me the pinouts. I have a Jetta 2000.
while I'm replying,
here's an off topic questio, but since you're talking about Jettas:
any one here know the wiring for the VW Jetta radios?
I go the dealer FAX me the pinouts for my Jetta 2000 (standard, not a monsoon) radio, but it's got NO detail. Can anyone help explain what the wires do?
Michael
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
amp +sub question talonesiboy Car Audio 8 08-28-2006 10:31 PM
Amp Sub Question!!!! Ahhh mikeforlife 4Runner/GX470 3 10-31-2004 12:35 AM
amp/sub combination question HERE pecos bill Car Audio 4 08-19-2004 04:09 PM
Questions on Installing an Amp/Subs AznVirus Audio/Security 28 02-02-2002 02:31 AM
