Old 12-29-2003, 01:47 PM
Grandpasgalaxie Grandpasgalaxie is offline
1965 Galaxie 500 Carb leaks
I just inherited a 1965 Galaxie 500 with a 390 V8. The car hasn't run in over 4 years. I was able to get it fired yesterday but the front float bowl on the 4 bbl carb is leaking horrifically! There is a rubber plug which is openned by the linkage and it doesn't seem to seal correctly. Does anyone have experience with these carbs? Where do I start on reparing it?
Thanks!
Old 12-30-2003, 07:40 PM
PWMAN's Avatar
PWMAN PWMAN is offline
What kind of carb is it? 2bbl, 4bbl, holley, etc? Square flange or spreadbore?
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 03-26-2006, 09:20 AM
Daddytiel Daddytiel is offline
Send a message via Yahoo to Daddytiel
Talking Re: 1965 Galaxie 500 Carb leaks
Thanks!
The float and/or inlet valve are sticking open and flooding out the vent hole. It could be varnish from old gas, dirt, or the valve could be wore out. Ford 4bbl carbs are not hard to rebuild as long as the throttel shafts are not worn.
1965 Galaxie alternator question???????? speed1975 Galaxy 4 03-05-2005 02:17 PM
1965 galaxie frame rot will a 1962 frame work curb to curb Galaxy 1 01-22-2005 03:53 PM
