Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-29-2003, 11:17 AM
sageprime1 sageprime1 is offline
Send a message via AIM to sageprime1
rsx tuning
okay, i'm running with 550cc injectors at 5psi (will go up to 7-8 later on). I want to know if anyone knows what the ratio's/correction should be for each rpm with this car using the apexi s-afc II. Also, i'm running rather rich, and am noticing that on start up, i'm misfiring so i need help with this tuning quick. anyone please help.
HEY...it's not my fault, the car sees u and it sees that u've been defeated!!!!
Old 12-29-2003, 12:28 PM
teglsturbo teglsturbo is offline
Your injectors are too big and are going to be rather hard to tune. Best suggestion is to take it to a dyno as soon as possible. But for now try running the safc at about -40 all accross the board. For your start up problem; mess around with the safc until you get it to idle right, it should be between -40 to -45 but every car is different. Take it to a dyno, thats the best way to tune everything to perfection.
Old 12-29-2003, 10:46 PM
Re: rsx tuning
okay thanks, but i have to correct you on one thing, the injectors are not too big, the smallest i can run with this turbo is 440, 550 is best if i plan to up the booast which i do in the long run....anyway, thanks!
built RB25det E-manage Ultimate Tuning... need a little help Modern_Performance Technical 0 07-31-2010 11:25 AM
can someone help me tune up my 2005 Mitsubishi Lancer Ralliart mike9000 Lancer 5 12-10-2009 01:40 PM
vibration problem need an expert my rsx is falling apart need HELP!!! 2003rsxtypes Let's get Technical! 1 09-27-2009 05:48 PM
Extreme Tuning Car Show Tijuana 2009 Advanguard Car Videos 0 06-04-2009 02:27 PM
RSX and RSX-S Information about MODS talonguy97 Integra 1 01-23-2002 12:35 AM
