Old 12-29-2003, 09:23 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
need all ur knowledge!!!!!!!!!!!
ok guys, i'm searching for my transmission, i need to know exactly what will work with my car, its an 89 Civic Hatchback, d15b2 5 speed. what transmissions can i get that will work with it??? i need to know ASAP
please help guys
thanx
Old 12-29-2003, 11:49 AM
1PhatCX's Avatar
bump!
Old 12-29-2003, 11:59 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
ZC transmission with an Si final drive
What's wrong with the DX transmission? I'm a weird kind of guy, because I actually like how it's geared.... seems just right for me.
Honda Enthusiast
Old 12-29-2003, 12:00 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..essentially any tranny from a 88-91 civic/crx will 'technically' work...
SOLD!
Old 12-29-2003, 12:12 PM
91civicDXdude's Avatar
JDM DOHC ZC transmission
USDM:
D16A6 Si
D15B2 DX
D15B6 HF
D15B1 STD 4 speed
any d series transmission will work, even the 92+ hydraulic trannies, although you'll need the kit to swap to hydraulic transmission as well as a B series mount kit.l
Old 12-29-2003, 08:49 PM
1PhatCX's Avatar
so i can use ANY 4th gen tranny without modifying anything?!?! someone said theres a difference on starter locations on some :S
i called and found one for my car (dx tranny) for 150 dollars cnd with 132000 km on it
what should i look for when getting it??
Old 12-29-2003, 11:57 PM
spin the input shaft to check that it spins freely (it will be a little bit tight, but you shouldn't have to strain).
check the input shaft for side to side play
inspect the axle receiving holes for any stripped gears or broken pieces.
Also, its not a bad idea to take the drain plug out to check for any metal shavings in the oil, or to see if its black (it shouldn't be).
Old 12-30-2003, 01:14 AM
SiZ's Avatar
SiZ SiZ is offline
Re: need all ur knowledge!!!!!!!!!!!
Get an Si tranny!!!
"The nympho of info, I'm fuckin' what ya heard"
Old 12-30-2003, 06:53 AM
slave slave is offline
BANNED
Yeah, I love my D16A8 with original tranny, rebuilt it, cant fault it.
JDM IS NOT LHD
My other car's a Porsche, but today I'm in a hurry.
Old 12-30-2003, 08:20 AM
dr_latino999 dr_latino999 is offline
Send a message via AIM to dr_latino999 Send a message via Yahoo to dr_latino999
I believe the starter is different between an automatic and a manual, am I right?
Old 12-30-2003, 09:25 PM
1PhatCX's Avatar
we got the tranny already, i havent seen it yet. my dad bolted it on already tho, not 100% done, still need oil and gotta put the axles, battery and intake back in, then its done, i wanted 2 get an Si tranny but my dad said just get the one i already called about
oh well, once i get my ZC when i find enough money i'll have a better tranny and stuff lol
any and all knowledge pepper_brown06 F Series 4 08-23-2008 07:52 PM
In Need Of Knowledge About Tranny's murph7727 Caravan | Voyager 2 12-21-2004 03:40 PM
needed "ford" knowledge on engine swap Macgyver007 Mustang Talk 8 06-17-2004 02:11 AM
HYBRIDS/SWAPPERS! I need your knowledge! ex2fast4u '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 15 10-11-2003 10:52 PM
I need all this stuff!!! Phat_Si '71-'87 Civic | CRX 3 01-10-2002 07:56 AM
