Old 12-29-2003, 12:19 AM
DiGiTaLEcLiPsE's Avatar
DiGiTaLEcLiPsE DiGiTaLEcLiPsE is offline
Send a message via ICQ to DiGiTaLEcLiPsE
Sanding..
I read the whole how-to primera man had posted. I need to know one thing : Where do I buy 600, 800, 1000, and 1200 Grit Sand Paper? Which brands?
Old 12-29-2003, 01:02 AM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
Re: Sanding..
tamiya makes #240, 320, 400, 600, 800, 1000, 1200, 2000 grit sandpaper.
Ya know HLJ is the main source
for more fine grit such as #2000 or above , you can try "3M". They make #2000, 4000, 8000, and 12000 grit sandpaper. They come with 3 sheets and in the same size as tamiya. However, the price is more than double of Tamiya.
just my cents......
Old 12-29-2003, 01:42 AM
Cool.. I found these on HLJ, are these the sand papers tamiya made?
Rough Sand Paper : http://www.hlj.com/scripts/hljpage.cgi?TAM87009
Fine Sand Paper : http://www.hlj.com/scripts/hljpage.cgi?TAM87010
Super Fine Sand Paper : http://www.hlj.com/scripts/hljpage.cgi?TAM87024
Old 12-29-2003, 01:48 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Re: Sanding..
Don't use sandpaper use wet and dry.
Your local Car/Auto store will also carry those grades of wet and dry.
Steve a.k.a. Hiroboy
Old 12-29-2003, 01:57 AM
I am only 15 I am un-aware of the closest auto stores.
Wet-Dry?
Old 12-29-2003, 02:05 AM
Oh yes, also to add onto the topic. I was wondering, when I wet sand the body. Do I sand the whole plastic body? Or music I sand only the defected parts? And Do I have to put anything onto the body before I sand?
Old 12-29-2003, 02:07 AM
cyclone1410's Avatar
cyclone1410 cyclone1410 is offline
Honda Convert
Re: Sanding..
Wet-Dry?
Use the white/yellow/pink pages or check the 'net to find your local auto store. Wet and Dry paper can be used to sand a surface dry or can also be used wet (with water) to provide an even smoother finish. The water acts as a very mild cutting compound, also helps clean the paper and the surface you are sanding and, lastly keeps the surface cool (acts as a coolant). Most auto stores (Super Cheap or Autobahn in Australia) will stock grades up to 12000 grit and even some hardware stores (Bunnings in Australia) have 5000 grit wet and dry paper available. Hope this helps.
Good Grammar is Not a Time of Waste.
Old 12-29-2003, 02:11 AM
I wish it did!
But I am located in Canada,QC and I ... am confused..
Old 12-29-2003, 03:20 AM
Honda Convert
Re: Sanding..
I wish it did!
OK I am happy to help you. Let me know what bits you are not clear on or confused about and I will try to explain them better.
Old 12-29-2003, 06:01 AM
David_ David_ is offline
Re: Sanding..
lol, dw about sanding unless its panel lines, and when u do that, work it off, then use super fine wet/dry (wet sand paper basicalyl, just add water) to get rid of the scratches, but imo, u don't really need to sand all over.... that just added scratches to my model.....
if u really need the paint to stick, use primer
Old 12-29-2003, 10:14 AM
So, I sand the plastic? Cause I don't know if you sand the plastic or put something on the model first.. ?
Old 12-29-2003, 11:10 AM
ProSStreet's Avatar
ProSStreet ProSStreet is offline
Re: Sanding..
i sand it all because that way all the surfaces are an even smootheness
Old 12-29-2003, 11:14 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Re: Sanding..
I think they pretty well laid it out for you, sand the model under running water nothing else required, the water acts to lubricate and removes the sanding particles. Wet sanding can also be done on the first few coats of paint to remove and dust, dirt or other defects
"u don't really need to sand all over.... that just added scratches to my model....."
this is not a true statement if you are using the correct grade of paper, if its leaving visible scratches your paper is to rough.
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
sanding base for clear? Swansen Auto Collision Network 7 07-22-2009 11:31 AM
1st time wet sanding & uhh... did i mess up sanding or painting? chato de shamrock Car Modeling 13 03-10-2007 07:28 PM
Sanding or not sanding Svendsen Car Modeling 4 06-08-2006 11:25 AM
I need sand ladders. Matt Peckham Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 07-24-2001 06:30 PM
