Old 12-28-2003, 11:56 PM
ricerwannab ricerwannab is offline
Send a message via AIM to ricerwannab
94 caravan NEED SOME HELP!!!
im not sure what it could be but if im going down the highway and let off the gas, the rpm's drop to lower than 500 and bounce back up again. It has about 140,000 miles on it and i just replaced the O2 sensor. the spark plugs and fuel filter has also been recently replaced. I ran the scan and got the code 32. I am not sure what that is. If someone could help me, i would really appreciate it.
Old 12-29-2003, 12:36 AM
larry101 larry101 is offline
code 32
code 32 is a egr (exhaust gas recirculation) circuit problem.
Its either the egr solenoid or a malfunctioning egr system(valve)
The solenoid should be tested first and if functioning properly the valve could be clogged open or shut.
This would cause the dropped rpm due to improper air fuel mixture.
hope this helps.
Getting some detail done, need some help FireFromTheGods Exterior | bodykits | Lighting 0 10-06-2004 11:00 PM
need some help resizing some pics for my sig twdz28 Camaro Discussions 2 09-02-2004 01:50 PM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 08:03 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 10:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 11:32 AM
