Old 12-28-2003, 08:35 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
1993 5.0 problem
I need to ask y'all about how to unlock an ignition on a 1993 Mustang 5.0. My girlfriend is trying to troubleshoot this problem for her granddad, who is too elderly to fix it. When the key is in the ignition, it will not turn, and the steering wheel is locked.
She's attempted to take the ground cable off of the battery, checked for blown fuses, and hasn't found the problem yet. Any suggestions you can give me would be appreciated, cause I've got no idea how to help her. Doesn't help that she's an hour and a half away...
Thanks fellas.
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 12-28-2003, 09:21 PM
Rodek Rodek is offline
Re: 1993 5.0 problem
have you tried wiggling the streeting wheell whiel trying to turn the key..cuase my mom's car does that as well, you can lock the wheels after the car is off...i don't know what it is for..maybe so peple can't roll off withy ou car..but ijust wiggle the steering wheel while tryig the ignitition and it usually unlocks it
Old 12-28-2003, 10:36 PM
Yeah, that didn't help her at all. I'm fresh out of ideas, this just happened out of the blue...
Old 12-28-2003, 10:51 PM
eillob's Avatar
eillob eillob is offline
Try turning the wheel counter clockwise and hold it there why you try to turn the key. If the wheel is locked this puts strain on the key lock.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 12-29-2003, 07:01 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Yeah, it does take some effort to release the wheel after it has been locked.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-29-2003, 09:36 AM
Okay, I'll tell her to try this, and then try it myself when I'm out there again next. I'll see if I can help her troubleshoot it then as well, and then post what I find out afterwards...
Old 12-31-2003, 08:33 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i have the opposite problem in my notch... ignition switch will turn with no key at all, occasionally... it's simply worn out. go to the ford dealer, give them the VIN number, and they'll press you a new set of keys. i'd say, 80% chance it'll turn right away. otherwise, thing about replacing the switch ($50, about an hour's work)
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
