Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-28-2003, 07:48 PM
mehtools57 mehtools57 is offline
2000 malibu no start
Cranks but wont start, 50K on the odo. Replaced blocked fuel filter. Car will start and runs fine when started. When it doesn't start I have figured out that if I rock the car, fi about 2 minutes it will start. I use injector cleaner in the fuel and also water evaporator. Any clues would be helpful.
Old 12-29-2003, 11:40 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 2000 malibu no start
Have you checked the fuel pressure when the car won't start?
You will need to check that and for spark when the car will not start..this will lead you towards what system is causing the problem...once that is done, then you can determine if it is a control circuit problem or a part failure
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-29-2003, 12:07 PM
Fuel pressure while cranking has not been checked. I have checked ignition and it is good. I will see if my pump is weak. I am guessing that is where you are headed. Thanks I will let you know
