Old 12-28-2003, 05:36 PM
tjmax43 tjmax43 is offline
Question no fuel
having a problem getting fuel,put fuel in throttlebody it will run for a second then die.no fuel getting to injectors.checked fuel pressure on fuel rail no fuel comes out.had a burned fuseable link going to the eec.relay replaced got spark but no fuel,need help almost got it going.thanks.p.s.have a 1985 ford f150 302 engine fuel injected.
Old 12-29-2003, 09:31 PM
Re: no fuel
maybe you should change your fuel pump,hope this helps.
Old 12-30-2003, 05:03 AM
89titSHO 89titSHO is offline
Re: no fuel
You do realize that you answered your own question, right??
Old 12-30-2003, 05:56 AM
Re: Re: no fuel
i figured maybe that would be an attention getter cause i really dont no.thanks for some real input.
Old 02-19-2004, 05:15 AM
washaw washaw is offline
Re: no fuel
Did u get it yet ? my250 has been down over a month and we are about to change the ext. pump(high pressure) my b/f has 91 F150 and he just went through replacing all the sensors and then cleaned the injectors. who knew? he spent close to $400 before doing the injectors for free.
Old 02-19-2004, 11:52 PM
Re: no fuel
yes i finally got it.it was computer relay under the dash.when i replaced it my truck started right up.thanks.
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
