Old 12-28-2003, 01:40 PM
TopDogg TopDogg is offline
350 TBI studdering under load???????????
I am close to buying a 1989 Chevy 4x4 with a 350 TBI. While the truck is in nuetral or Park the engine will rev just fine through the whole RPM range. When you are driving it the truck will pull away from a stop and drive good also but when you want to take off fast or pass someone it will start to cut out at about 3000RPM. So its hard to get to a higher speed fast but once you get there it will hold the speed all day long. I havent tried any tune up things yet because its not my truck so troubleshooting isnt an option right now. So i am just looking to see if anyone has had the same problem or knows that it might be ONE SPECIFIC thing.
Old 01-16-2004, 10:46 AM
BigRed04Silverado BigRed04Silverado is offline
Re: 350 TBI studdering under load???????????
First check your spark plugs or have the seller do it. One bad plug will cause this. I know from experience.
Fuel injectors may be dirty. Use any store bought cleaner in your tank or you can get it done for about $50-$100. Be sure and change plugs and filter after this is done. Should eliminate the problem
Red 04 Silverado 1500 4x4
6'' FABTECH Full Suspension Lift
BFG TA KO Tires
American Racing Dimond Series wheels
Flow Master 40 Series dual with 18'' stainless slash cut tips
Drop in K/N
Tinted Windows
Old 01-16-2004, 02:45 PM
There was a previous reply on here and I guess he deleted it. But he had it right and I never would have gueesed it was in the tranny. All the stuff you mentioned I keep up with regularly. Thanks anyway.
Hope you didnt pay to much for that Fabtech lift.
