Old 12-28-2003, 10:20 AM
alex3rail alex3rail is offline
92 4X4 Front Diff. Problems
The actuator pin where the cable attaches on the diff. is stuck in 2 wheel drive. I need info on the internal workings of the front diff and what may be stuck or broken inside. Prior to this actuator sticking I was having a hard time getting the front diff. to engage and staying engaged. I purchased this truck less than one year ago and at that time the tranfer case vacum switch was stuck in the engaged position. I replaced the vacum switch and the cable shortly after buying the truck. After replacing these items actuation was no problem but only tried a couple times on gravel and did not try to actuate again until the snow started flying this winter.
Thanks In Advance...Sean
Old 09-24-2004, 11:56 PM
steelerfan820 steelerfan820 is offline
Re: 92 4X4 Front Diff. Problems
check tpo see if you are actually getting vaccume pressure it the diaphram just before the cable if not theres your problem
88 4x4 front diff trouble Dave884x4 S-10 0 02-19-2010 11:56 AM
04 front diff problems duramax04 Silverado 1 07-14-2009 04:25 PM
2000 S10 front diff problem tofor325 Problem Diagnosis 0 10-22-2006 04:00 PM
'95 4x4 Front Diff Problem RevJFP Problem Diagnosis 9 10-17-2006 07:57 PM
91 4x4 Front End Problems Acme54321 Pick-Up 0 04-05-2004 11:44 PM
