Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 12-28-2003, 06:01 AM
Wrum Wrum is offline
Fitting Vent Rings
Hi all and greetings from the UK.
I have an '03 Hyundai Coupe V6, or Tiburon as they call it in the US...
I recently purchased some billet vent rings from Shark Racing - pretty good service and prompt delivery - only trouble is they don't come with any fitting instructions.
I've managed to fit the two rings that go on top of the dash at either end but I'm struggling to fit the centre rings - The old rings don't seem to want to come off and I'm reluctant to use too much force in case I wreck the dash. Anyone already fitted these or have any ideas on how to fit them?
Any advice welcome.
Thanks,
Wayne.
Old 12-28-2003, 10:35 AM
tibby01 tibby01 is offline
on my 01 tib, i did have to use quite a bit of force when getting the vent rings off. nothing bad happened. i think there were little balls in the plastic that you have to get over, which makes them hard to push out.
Old 12-29-2003, 05:25 AM
Re: Fitting Vent Rings
Cheers for that; I guess I'll try again and use a bit more force now then!
Old 12-29-2003, 06:04 PM
you do know about the clips that hold them in right? im assuming you do. just try to bend the rings around the little balls in the plastic, it is hard, but will work.
Old 12-29-2003, 06:27 PM
skuuter skuuter is offline
Wrum,
Simply take a straight edge rzor and place it between the ring and the dash. You need this to protect the dash. Then, take a hacksaw blade or box cutter and slice through the top center of the plastic vent ring, keeping the straight edge in front of your cutting tool. Once you're through, pull outwards on each side and the ring will snap off. The new garnish rings will fit onto the retainer very snugly. Throw the old rings away and you're done!
Old 01-13-2004, 03:05 PM
Re: Re: Fitting Vent Rings
Originally Posted by skuuter
Wrum,
Skuuter,
Took your advice and hacksawed them last Sunday...
Thanks to the other guys also for your suggestions.
Wayne.
Ring and Pinion Upgrade? TONYABITZUSMC Silverado 7 07-28-2010 10:46 AM
Tool for the Retaining Ring? schri00 Impala | Impala SS 2 05-31-2010 01:43 PM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
'99 vent ring removal jennygmhs2k2 Grand AM 0 01-04-2006 12:08 PM
Vent Rings Adam_Hunsicker Tiburon | Tuscani 2 02-15-2004 09:31 AM
