Old 12-28-2003, 03:08 AM
matt56 matt56 is offline
Question anyone with a 97-99 GST i have question
im 16 and i was thinking about buying a 97-99 GST for my fist car and was needing to know what insureance will run on it for me? and what's the differance between insurence for GS vs GST? thanks
Old 12-28-2003, 04:35 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
you insurance is probably gunna be quite spendy if you get the GST since you are 16, the difference is GS has no turbo and the GST has a turbo. the insurance on the GS will probably be a little over half of what the GST would cost!
Old 12-28-2003, 08:01 AM
diviniti's Avatar
diviniti diviniti is offline
Send a message via AIM to diviniti
Re: anyone with a 97-99 GST i have question
I suggest putting the car in a parents name and your name. that way you can go under their insurance policy.
check www.progressive.com
and www.geico.com
For an "idea" of rates are going to cost.
remember that if the car is baught under some type of loan, 99% of the time you will need to have full coverage on the car.
Old 12-28-2003, 12:02 PM
95GSTRaCeR 95GSTRaCeR is offline
I am also 16 and I own a 95 GST. I used to have a 95 GS and EclipseRST is right my insurance is double now. I currently have to speeding tickets on my policy. One 47 in a 35 and the other was 101 in a 65. Even with the 2 tickets I am paying $130 a month for liability, which is cheap for a GST, but I also payed for my car in full and have no loan out on it. If you are going to have to take out a loan to get the car then the bank will make you put full coverage on it and I got quoted something like $360 a month. The other thing that is going to make a difference is where you live. I live in northern minnesota. So where you live can make a difference also.
Old 12-28-2003, 12:59 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
97 GST here
I got mine was I was 16, the insurance was about $2400 a year full coverage
but guess what
I saved a bunch or money by switching to Geico
-Agim
Old 12-28-2003, 01:36 PM
i also wanted to know what crank walk is and is there any thing you can do to prevent it? BTW i think ill get a GS! 360 a month is way TOO MUCH! ill just go all motor and rebuild it, bore it out ect. whats a safe bore size for a GS motor 30 over? higher?
Old 12-28-2003, 02:25 PM
diviniti's Avatar
crankwalk is when the main bearings fail in the motor and the crank actually walks out of the block..
Old 12-28-2003, 02:51 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: anyone with a 97-99 GST i have question
you shouldn't have to worry about crankwalk too much, it's pretty rare and only on the 4g63 motor built in the mid 90's... www.2gnt.com click that for non turbo performance... my insurance is like 2600/year, full coverage and i got like 6 points, i'm 25, and i live in CA... check the progressive website, it's real easy to calculate your rate and you can click for other competative rates from other companies... and don't forget to make your deductables high...
Old 12-28-2003, 03:59 PM
EclipseRST's Avatar
Banned
ok your wrong about the whole crankwalk thing... crankwalk can happen to the 420a motor too not just the 4g63, and it is less likly to happen between 90-92, that would be the years of the 6 bolt motor! from 93-99 they switch to the 7 bolt motor that is more likly to get it, although yes it is not a common as a lot of people make it out to be... you should really have to worry about it if your car has higher miles...like 80k and above cause if your car hasnt gotten it by then it probably wont get it!`
Old 12-28-2003, 04:10 PM
i thought crankwalk was due to a factory defect on the crankshaft manufacture only on mid 90's 4g63 cranks...
Old 12-28-2003, 04:18 PM
ok after a little more research, i guess i came to that about mid 90's 4g63's because they are the most prone to it, although others are susceptible. but it is very rare none the less...
Old 12-28-2003, 04:41 PM
oxygen800r's Avatar
oxygen800r oxygen800r is offline
i got a 98 gst, full coverage insurance is $150/month. i live in austin, have zero tickets or accidents, and am 23. i guess that's why. but i live in the hood and have $5K aftermarket coverage...it carried over from my crx that was actually modified.
my dsm is actually untouched...for now.
Old 12-28-2003, 04:50 PM
where did you get 360 from?
and btw,If you get a GS you dont have to worry about crankwalk,
I suggest you test drive each car first
-Agim
Old 12-29-2003, 01:48 AM
kjewer1 kjewer1 is offline
AF - Advisor
Any motor can crankwalk. Old chevy V8s did it often as well, they jus tdont call it that Its when the thrust bearig fails, not the main bearings. The crank doesnt walk out of hte block either, it only has to move .009 inches to be bad.
Not really what you are looking for, but my 95 GSX costs me 50 per month.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-29-2003, 02:16 AM
diviniti's Avatar
damn! just keep shooting my posts down..
main bearings, thrust bearings, same diff.. gimme a break I havnt owned a DSM in 2 years. im just now getting back into it. (shoot me)
and how isnt it walking out of the block? no matter if its .009" or 5" - its still "walking" out of the block. a friend of mine's old 97 GST had it very bad, to were you could actually look up at the pully and see it moving. at first we thought the pulley insert had went bad, and he needed a new pulley. but in the end CW got it.
Need 97-99 gst wiring harness evogst Classifieds 1 11-24-2006 09:26 PM
Anyone have a Red 97-99 Front bumper? scottsee Classifieds 0 10-20-2006 02:36 PM
Anyone with a 2005 G35x having front brake problems? andy2812 G35 Sedan 3 01-11-2006 04:52 PM
anyone selling a 97-99 eclipse gst???? Eclipse_gst Off-Topic 0 08-17-2004 12:01 AM
Anyone have any 97-99 OEM Side Skirts For Sale??? rsclipse27 Off-Topic 0 05-12-2004 07:20 PM
