Old 12-28-2003, 01:14 AM
BURGIEDANNY BURGIEDANNY is offline
It won't turn off
I HAVE AN 87' CAMARO WITH A 5.0. When I try to turn it off, it idles for about 5 seconds then sputters off. It does'nt seem to be dieseling, but I could be wrong. Anybody got any ideas?
Old 12-28-2003, 08:57 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: It won't turn off
It might be your ignition switch.
Old 12-31-2003, 06:29 AM
Jays76Camaro Jays76Camaro is offline
Send a message via AIM to Jays76Camaro
Sounds like the idle is set too high...adjust the solenoid on the carb but if you have FI, then just shut the car off in drive - that's what I used to do when I needed to replace my carb gasket - too much air was coming in and I couldn't turn the car off without it dieseling
I want my car to look nice for the womens
Old 01-01-2004, 01:26 AM
crapmaster4000's Avatar
crapmaster4000 crapmaster4000 is offline
the best idea ever!f
Take it to the repair shop, when she comes back its good as new.
Old 01-01-2004, 01:50 AM
hot(gay)Rod hot(gay)Rod is offline
Banned
seen this problem before, here's the fix. got to your nearest hardware store and get a door hing. bolt that puppy to your carb or throttle body so it hinges away from the manifold. reason being, if it wont shut off, you can just flip the carb or throttle body away from the manifold so the engine cant get gas-no gas-cant run. problem solved
