Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-28-2003, 12:35 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Question High-compression & turbo
I was out with the Columbus crowd tonight, and this guy has a brand new Garret turbo (just the snail, no manifold or anything) he's selling for $150. He bought it for $400 but his engine died before he could install it. That sounds like a great deal to me. I want to buy this but my quesitons are, first of all, would it even be a good idea? I want to run about 4psi on stock compression on my B16B. How much hp will that add, and what parts would I need besides a turbo mani and piping? Would I need larger injectors for only 4psi? Anything needed to "fool" the ecu (like a missing link on a sohc)? I'm sure my engine could withstand 4psi, but if I'll only see 20-30 hp out of it and will need $500+ in parts JUST to get it running right (no optional mods yet like an intercooler/boost controller/bov), I may have to hold off a bit. Any suggestions/opinions/thoughts?
Old 12-28-2003, 06:54 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Well, in general, they say that 1psi=10hp. I am not sure how that works with such low boost though. Still, the B16B runs a 10.6:1 c/r, so I wouldn't wanna boost that. A missing link, or somethig similer, is a good idea, to say the least. It will help "trick" the map sensor. There are other routes, but you're trying to keep the cost down, since it's only 4psi. There are cheap boost controllors you can get if you want...turbo XS has some affordable "manual" boost controllers. Maybe like $79 or so. You'll need a BOV for any turbo system, so chaulk that cost up. Nothing fancy though. You can probably get a used DSM BOV fairly cheap that would work fine. Also, I would think that you'd need a slight injector upgrade. I'd do it just to be safe, as you don't wanna go blow your type-r. Even on low boost, given the very high c/r of a type-r motor, I would definatly get an intercooler. Hotter temps can cause pre-detonation, as can a high c/r mixed with boost. Mixing both of those is not a great idea. If you wanna try and boost that motor, get an intercooler. It will add more power, plus help reduce the chances of pre-detonation due to the hot air temps a turbo creates. You get a 1% gain in HP for every 11.1 degree's you lowe the intake temp, and some intercoolers can knock upwards of 100 degree off the air temp. If it were my type-r motor, I wouldn't do it. Type-R motor's are for n/a apps. A high compression ratio and boost usually isn't a good idea. Though I have seen in pulled off successfully twice. Both times, though, the car really wasn't raced at all, plus the guy's knew a hell of a lot about tuning. So it's a different case with them, that's not a combo most people want to run. If it was me, I'd pass on it...but that's me. I hope this helps a bit.
(see why my posts are so long? To better inform the person asking the question, like you in this thread)
Old 12-28-2003, 01:50 PM
Ricochet's Avatar
Banned
Re: High-compression & turbo
Thanks man. Oh well, maybe I can get my friend to buy it for his LS Integra, I'm sure he'd have more fun w/it than me. Since I'd have to buy all the turbo neccessities any other car would need, there's no way I'm going to spend that much for such a low output. Guess I'll have to keep saving for the Spoon 1.8 stroker kit instead.
Old 12-28-2003, 02:53 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Yeah youre looking at about a grand just for manifold/downpipe fabrication, so Id say forget about it.
Old 12-28-2003, 06:15 PM
Honda God
Re: Re: High-compression & turbo
Yea, that's probably a better idea. Your friend you definatly get more use out of the turbo. The Type-R is a killer N/A motor, doesn't need a lot of upgrades to be very potent. Kind of like the LS is with a turbo. You looking at getting the Spoon Stroker kit they're selling at inline4.com? I've checked them out before too. You got your motor from them, correct? BTW nice pic's of your motor in the other thread. I can't beleive that guy in there, he and CrXb18c1 must be buds or something.
Old 12-29-2003, 12:28 AM
Ricochet's Avatar
Banned
Re: Re: Re: High-compression & turbo
yeah, been a lot of them lately..
How much power with the stroker add? I'm not too sure about the numbers except it will raise displacement to 1.8, surely adding some torque...
Old 12-29-2003, 01:18 AM
Honda God
Re: Re: Re: Re: High-compression & turbo
Yea, it will definatly add torque and hp....just how much the spoon kit adds, I am not sure. I'll let you know if I find anything out.
Old 12-29-2003, 09:18 AM
Noremac Noremac is offline
Send a message via ICQ to Noremac
hey Ricochet have you ever been to Passen in Columbus?? I've heard a lot of good things about that place and they helped to steer some people i know in the right direction with what to do with their cars.. passenmotorsports.com is there website but it doesnt have much..
95 ls with GSR head
aem cai, dc sport header, greddy exhaust, pyr computer chip(red-8500) type r pistons, skunk 2 intake manifold and coilovers, aem fuel regulator, msd ignition wires, unorthodox underdrive pulley And Now Skunk2 stage 2 cams but not installed..
all sleepin in a black body...
Old 12-29-2003, 01:01 PM
CougarSVT CougarSVT is offline
Send a message via AIM to CougarSVT
Passen is good.....they are usually backed up though. I have heard more good than bad about them.
Dealer for Turbonetics products...cant beat our price!
Dealer for SCT......fine tuning software
T3/T4e, super series, Hybrid, stage III Turbine $650.00+tax
T3/T4e Ball Bearing, Hybrid stage III Turbine $1,050.00 +tax
Turbonetics EVO wastegates...$200.00!!!
Turbonetics Raptor Bypass Valves
Turbonetics Turbo kits for Civic's, Preludes, GSR's for $2,999.00!!
Spearco IC's from $225.000
PHONE #: 937-336-1462 ask for Stephen N Brown
********HAPPY HOLIDAYS********
Old 01-01-2004, 02:20 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
that spoon stroker kit looks like a pretty good deal. Does anyone know if it would work on a B16A3????
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 01-01-2004, 03:01 PM
Ricochet's Avatar
Banned
I've been going to Passen for years.. They're a pretty good store with cool guys, I even hang out with one of them outside of work (Tommy).
Old 02-01-2004, 08:00 PM
civtypeR civtypeR is offline
richochet i have a b16b and if you check out SSAUTOCHROME.COM you will find a very nice inexpensive show quality manifold
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
