Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 12-28-2003, 12:32 AM
mistskater mistskater is offline
Send a message via AIM to mistskater
burnout
can anyone tell me how to do a burn out? i can burn out in real wheel cars by powerbraking but in my focus, it being front wheel drive i can't do a burn out. can anyone tell me how to?
Old 12-30-2003, 12:18 AM
coloradolove coloradolove is offline
Re: burnout
wait till a snow fall, and then try to drive that thing up a hill...it'll burn out real nicely. Are you drag racing on a track? Cause they have a burnout box there, but otherwise, don't waste your time or tires man
Old 12-31-2003, 07:30 AM
freakray freakray is offline
AF Modelrater
Re: burnout
Is your car an automatic or manual transmission?
Old 01-01-2004, 01:24 AM
SIKCRX SIKCRX is offline
Re: burnout
if its an auto, then pull the ebrake up and hit the gas. but just so you know, i saw a picture in MM&FF and they have a project focus(stock) and they couldnt even get the tires to spin enough to make more smoke than a cigarette.
Old 01-09-2004, 01:06 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: burnout
put that fucker in R and punch it then slam it in 1
Old 01-09-2004, 03:07 PM
AF Modelrater
Re: Re: burnout
And then replace the gearbox since you'll be damaging the transmission doing this.
Old 01-10-2004, 10:33 PM
lewdaka03 lewdaka03 is offline
well if ur auto try a neutral drop at like 2 or 3k and if ur man. drop the clutch at like 3k or so and your wheels should spin... but it is really a waste if your cars tranny is not built or heavy duty like the Svts is... only do it if u got some 1 2 impress if you dont total waste IMO.
Old 01-11-2004, 07:56 PM
csramsey csramsey is offline
Send a message via AIM to csramsey Send a message via Yahoo to csramsey
Re: Re: burnout
we can smoke ours (full stock) as long as the traction control is off
Old 01-12-2004, 10:44 PM
urweak urweak is offline
Banned
Send a message via AIM to urweak
Re: burnout
well in order to do something like that, i would suggest adding about 40-50 more hp or more to your car then you should be able to do one. but if you want to bet on your car do a naturel drop.
Old 01-12-2004, 10:56 PM
Re: burnout
dumpin the clutch at 3000 rpms is unnecessary if you wanna do a stand still burnout, just release the clutch as you usually do and tap the brake as quickly as you can and punch the gas.
Old 08-09-2004, 10:52 AM
2-D 2-D is offline
http://memimage.cardomain.com/member...93_27_full.jpg my focus doing a burnout
its possible with a standard transmission.... dont know about automatics without doing a neutral drop
Old 08-10-2004, 12:27 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: burnout
you never neutral drop a transmission thats a good way to fuck it up and it wont make you do a burn out, just a squeal.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 08-26-2004, 04:16 PM
racer_r's Avatar
racer_r racer_r is offline
Send a message via AIM to racer_r Send a message via MSN to racer_r
You can also put the emergency brake on, but keep the button pushed and give it gas. That should cause your car to burn out.
I'm still Dreaming...
