Old 12-27-2003, 08:05 PM
Apollo 2 Apollo 2 is offline
Angry Auto door locks
After installing a remote starter (Prostart CT3300) on my 1995 Taurus Wagon, I still need help to wire the remote door locks and hatch release. The wires from the unit are 500mA negative output. Any help would be appreciated.
Thanks
Old 12-28-2003, 08:46 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Auto door locks
Thanks
It's pretty easy. You need to find the pink/yellow for lock and pink/green for unlock. Both wires can be found in either kick panel. You'll need to five-wire if your car is non-keyless , negative-pulse for the keyless versions.
Trunk pop is gray/red + at the switch. Again, you'll probably need to use a relay since most outputs are neg..
