Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-27-2003, 05:19 PM
johnm57 johnm57 is offline
no spark at coil
I have no spark at the coil. Not sure where to check all fuses look good.
Old 12-27-2003, 10:57 PM
addihs214 addihs214 is offline
Send a message via AIM to addihs214
Re: no spark at coil
Is did you check the plug going into the coil from the PCM? If you have a multi meter you can test that. Could your coil be bad?
Hope this helps
Dan
Old 12-28-2003, 02:07 PM
This is a 93 Dakota
Old 05-19-2004, 04:17 PM
gunzdonovan gunzdonovan is offline
check the distributor, or the pickup in the dist.
Old 05-19-2004, 07:58 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
And all wiring. Maybe something melted.
