Old 12-27-2003, 04:16 PM
michaelmeck michaelmeck is offline
want to go faster!!!!!
My friend has a 2002 gt and wants to know all of the low budget mods he can do. He already reworked all of his exaust and we pulled the front sway bar for a better launch but what can be done to the engine for little to no money???
Old 12-27-2003, 09:46 PM
95gts98gt 95gts98gt is offline
Send a message via AIM to 95gts98gt
Re: want to go faster!!!!!
pulley's nitrious intake throttle body mass airflow sensor new ignition spark plug wires....way too much too list
95 GTS...9mm FRPP spark plug wires, BONE STOCK
Old 12-27-2003, 09:51 PM
F23A4Racer750IL F23A4Racer750IL is offline
Grounding Systems but i dont know if neone makes them for domestics. could be wrong though.
Old 12-27-2003, 10:00 PM
y dont u just throw away that exhuast you bought and run open header no-body would know
Old 12-27-2003, 10:03 PM
thats gonna be too loud. just go cat-less
Old 12-27-2003, 10:05 PM
if your not running cats then whats the point of the rest of the exhuast
Old 12-27-2003, 10:10 PM
parrish5o's Avatar
parrish5o parrish5o is offline
Remove the intake snorkle from inside the right fender, bump your timing up to 14 degrees and most imporntant learn to drive. I'm not saying you can't most rookies don't realize how much better their timeslip will be with a percise launch and an ability to consistantly powershift
CANFIELD STAGEII HEADS SCORPION 1.6 COMP CAM 555/570
GT40 INTAKE STAGEII LOWER 65MM TB PRO-M 75MM MAF
30LB INJECTORS 190LPH FUEL PUMP/ NOS INLINE PUMP
FMS ZT5 CENTERFORCE CLUTCH HURST SHIFTER
ALUM DRIVESHAFT 31SPLINE MOSER AXELS AUBURN DIFF
ALUM RADIATOR MSD 6AL MSD ADJUSTABLE TIMING RETARD
NOS STAGE II 150HP 497@5800 474@4300 11.3@118
Old 12-28-2003, 12:02 AM
SIKCRX SIKCRX is offline
id say new gears...but im a n00b, what do i know
Old 12-28-2003, 12:28 PM
Re: Re: want to go faster!!!!!
cuz u cant see if the cats are off. u can see if theres no exhaust.
Old 12-28-2003, 02:59 PM
what cops these days matt especially in our area check to see if you have exhuast?
Old 12-28-2003, 03:23 PM
mycobra70la mycobra70la is offline
Low cost mods to go fast- hmm kinda contradicts each other.
Timing adjuster, Gears, lose weight.
Old 12-28-2003, 06:47 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
What is the point of this post? I'm confused as to what your trying to get across? Cats are restrictive, so running an off road pipe, will free up some power and make for a different sound, with mufflers. If you have no exhaust, just open headers, you are then losing all kinds of torque from lack of back pressure. Granted reducing back pressure helps, but there becomes a point were too little back pressure will hurt performance.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-28-2003, 08:37 PM
that it tru. i wouldnt go open headers on a farely modded car.
Old 12-29-2003, 01:43 PM
parrish5o's Avatar
Disregard what I said about the snorkle and timing. Just notice you were talking about 2002, that only works on a 5.0. My bad.
Old 12-29-2003, 08:12 PM
ok why do top fuel draggers run open headers?
