Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-27-2003, 11:04 AM
hbp hbp is offline
Question 97-Blazer AC-problem
The clutch om the AC-compressor do not engage.
Ha anyone some hint or electrical drawing for AC-installation.
Ulf Jansson
Old 05-09-2004, 04:49 PM
JasonJeardoe JasonJeardoe is offline
I have the same problem on my 96 Blazer. I called a shop and a mechanic told me that if the freon pressure is low, there is a switch that will keep the compressor from kicking on. He said to have it recharged, which I am going to have done tomorrow. If this fixes my problem I will let ya know.
Old 05-11-2004, 02:43 AM
cobra1 cobra1 is offline
Re: 97-Blazer AC-problem
i hope you know that if recharging works, your problem still isnt fixed unless you find and fix the leak.
Old 05-31-2004, 04:31 PM
funkamongus20 funkamongus20 is offline
It happened to me too. I found the accumulator, took out the plug, took a safety pin and cut off the end so it was circular on one end and 2 straights on the other, inserted them ( 2 ends) into the female part of the plug then touch the 2 males inside the connector with the circular end to jump the signal to keep the compressor on. then it took some of a can of r134. THen of course I took the jumper off and reattached the plug. It works well now. Good luck.
Old 05-31-2004, 05:19 PM
Re: Re: 97-Blazer AC-problem
you still need to find the leak and have it fixed, then recharge the system with the proper amount of freon. too much or too little can cause damage to the compressor.
Old 05-31-2004, 07:37 PM
actually, Im by no means a mechanic. I bought it from a guy in Vegas who was on the road as a musician and didnt use the ac for several months. Im hoping the seals dried out and it leaked out. Now I run it on a regular basis and its ok so far. Ive tried to put more in and it wont go. is recharging out of a can a real slow process? I watched the frost on the side of the can to watch it fall, it seemed like it stopped so I quit. Not quite one small can. What should I be on the lookout for in terms of damage to the compressor?
Old 05-31-2004, 08:14 PM
BJones405 BJones405 is offline
Take the switch off of the big silver looking tank and connect the two prongs with a screwdriver. If the compressor kicks in, then it's a low freon problem. Get it charged, pressure tested, and then you're good. I had the same problem a couple weeks ago and almost bought a compressor. The found a small leak near that switch. Let me know if it kicks in when you connect the two prongs
Old 05-31-2004, 09:31 PM
unless of course the pressure switch is bad and you need a new one. that happened on mine.
Old 06-24-2004, 02:48 PM
ice2626 ice2626 is offline
I have a 95 blazer, the system is fully charged, no leaks, blows ice cold air sometimes, and sometimes the compressor decides not to kick on. If I leave it on it usually stays on, but if i turn the ac off, and go to turn it back on, then It wont turn on. My problem has to be electrical, can anyone help me with what, or how to trouble shoot the electrical system. Has anyone else had any similiar problems with a relay or switch going bad? What switch or switches, or relay/relays can I jump or check, and where are they located? Any help would be greatly appreciated. Thanks.
Old 06-24-2004, 04:42 PM
Well I jumped the switch on the accumulator, it kicked the compressor on and Ice cold air came out. Put the wires back on and the ac is still working. Since I know the system is charged, can I conclude that the switch on the drier is going bad, or could it possibly be another switch or relay? Thanks ahead of time.
Old 06-24-2004, 06:37 PM
JS567 JS567 is offline
I had the same problem and the mechanic changed the ac relay and it works great now
Old 06-25-2004, 02:37 AM
the switch should be the culprit. i had to replace that very same one on my 95 S-10.
Old 06-13-2007, 05:13 PM
finstinct finstinct is offline
Thanks to all above me in this thread... This helped me out tremendously although I must admit I got scared when the gauge on the refill went to 125 psi and didn't come down... (Gauge was sticky) if you unplug the refil and plug it back in it reset to 25 lbs.. phew
THANK YOU ALL!
Old 06-17-2007, 11:08 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
welcome to af. glad you were able to fix the problem but this thread is almost 4 years old. please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
97 Taurus AC problem Fliegerbk Taurus | Taurus Wagon 4 08-09-2006 04:15 PM
97 Traurus AC Problem jwichman Taurus | Taurus Wagon 0 02-26-2006 03:41 PM
97 Blazer AC question 1997 S10 Blazer 6 08-01-2005 11:27 PM
97 z34 AC Problem AFDSKI Monte Carlo 1 07-31-2005 12:32 AM
2003 Blazer AC Problem...HELP!! jmat1980 Blazer 4 06-18-2005 07:44 PM
Closed Thread
