Old 12-27-2003, 06:23 AM
dr_latino999 dr_latino999 is offline
Send a message via AIM to dr_latino999 Send a message via Yahoo to dr_latino999
Crown Nut Snapped
So here I am cleaning my engine yesterday (D15B2) and I come to the valve cover. Test the crown nuts to make sure they are on nice and tight and the right hand front one is loose to the point I have play with it in my hand. So I give it a quick spin with the wrench and it snaps off, taking the top of the bolt. Now here is the question(s):
1) Is the engine in any mortal danger? The bolt still seems to be jammed in place so the valve cover hasn't moved.
2) How would I go about replacing the bolt? Is it simple or am I going to be digging around there like a strip mine?
3) Can I replace the bolt by myself or if I take it to a shop how long should it take to fix?
Old 12-27-2003, 10:09 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you might have to take it to a machine shop and have them drill out the old bolt, re-tap the hole and install a new one. it could begin to start a problem of not sealing correctly and you can have oil leaking all over the place.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-27-2003, 01:00 PM
BullShifter's Avatar
Re: Crown Nut Snapped
Remove the valve cover & replace the broken stud & crown nut. Should only be a couple bucks from the dealer. The fix is pretty simple. Since it is a closed nut, it can only be tighten so much. If the valve cover gasket is old, it may be wise to replace that also.
Old 12-27-2003, 08:40 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
like jackasssi said, just change the stud. hopefully the stud didnt break in the head, but rather the stud broke on your crown nut.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-27-2003, 10:02 PM
Ok, the good news is that it broke right up at the top, and it is flush with the valve cover. Does that make a difference in the issue? And the valve gasket is new, just put in about 3 weeks ago.
Old 12-27-2003, 10:18 PM
carguyinok's Avatar
carguyinok carguyinok is offline
If it's flush with the cover you should be good to do it yourself. Pull the cover and get a visegrip on the broken stud then turn it out. Just make sure you use care and dont scar up the head with the visegrips.
Rules of the game fast,good, cheap pick any 2
fast + good = not cheap
fast +cheap = not good
good + cheap = not fast
Because the water has no speed limits
Old 12-27-2003, 11:47 PM
cot's Avatar
cot cot is offline
As people are saying, it's not as bad as it looks. When you pull the valve cover off, you'll realize that the stud is actually fairly long, and there should be plenty of room to grab the stud and unscrew it from the head
it's not nearly as painful as if you broke a bolt off in the head or something like that. just be glad it broke at the top end and not the bottom!
Old 12-28-2003, 12:53 AM
Dont Use Vice Grips
Simply remove the remaing valve cover nuts
Remove the v/cover
Use a 10mm wrench or 10mm deep socket for removing the stud. An impact would be the safest for removing the stud.
DO NOT over tighten the new stud or crown nuts.
If you can't get a new stud, I have some at the shop & will sell for cost of shipping. Just let me know the length since there are various sizes - usually 2 long & 2 short on Honda's.
O/T Nissan v/covers are held on the same except with 10 or more crown nuts. I had a car recently in shop with 6 of the 11 broken .
Old 12-28-2003, 06:26 AM
Damn, if that was my car.... I get nervous for one.....but 6? I would be crying all around town. Ok, I am guessing since you want me to use a 10mm socket to extract it that this is just a standard bolt in, bolt out procedure, am I correct?
Old 12-28-2003, 12:15 PM
Yes it's a standard bolt-in procedure. The stud is basically a 2 ended bolt with a nut in the middle, 1 part goes in the head & other part goes through the v/cover for the crown nut. Once the v/cover is removed it should be pretty easy to figure out. Now if your having trouble removing the old stud, STOP & take it some where with an impact gun to reduce the chance of it breaking in the head.
Old 12-28-2003, 12:28 PM
carguyinok's Avatar
Sorry, didnt know they had a head in the middle you could get on Learn more everyday Most I have had to deal with are just blank in the middle.
Old 12-28-2003, 12:51 PM
Re: Re: Crown Nut Snapped
I've searched the manaul a few times & can not find any info on the studs, no torque spec/picture. I could always take a pic of one @ the shop if your that curious.
This is the best illustration I can find in the manual -- you can see the threaded rod at the top then a thicker post with a nut below that/mating to the cylinder head surface. Below the nut is another threaded rod, just like the top part.
Old 12-28-2003, 05:24 PM
Thanks jackasssi, all the info is gonna help. The earliest I can tackle this is on tueday -- im stuck at work tomorrow. Who would have thought people would be in a water park three days after christmas. So in conclusion, just go off to the dealership and pick up a new stud and etc? Sorry if I sound like a lost case, but busted studs (wheel and etc) arent covered in the standard manuals.
Old 12-28-2003, 06:42 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
I'm pretty sure the tq. specs are for 7ft lbs.
Check out my car here My 91 Hatch
Old 12-28-2003, 09:48 PM
Thats the first thing I checked after the nut went kaput. Now I will read all that information before tightening random odds and ends.
HUGE Wheel Lock nut issue! Need help finding the right key/socket to fit! Passatguy Tires and Wheels 4 08-31-2010 11:46 PM
Crown Vic 5 speed swap, help jnslick Crown Victoria 2 07-10-2010 09:34 PM
1998 Crown Vic Hesitats after wash fatcat0915 Crown Victoria 5 11-11-2009 03:58 PM
04 PI Crown Vic Zeepian Crown Victoria 0 03-29-2009 01:54 PM
00 GA Snapped off lug nut & intire Bolt! peteyboy310 Grand AM 3 01-21-2006 01:39 PM
