Old 12-27-2003, 07:11 AM
jussbringit jussbringit is offline
Send a message via AIM to jussbringit
starting problems
i have a 350 iroc-z when i start it up in the morning it starts fine but dies out quick but if i turn it to acssories and hear the fuel pump it starts fine. but if i start the car in the morning and give alil bit of gas its fine its like i have to give it alil bit of gas to start it and its fine. but if i drive the car for lil bit stop for like fine mins i can get back in the car and start it right up no probs. what do you think it would be? any help please.
Old 12-27-2003, 09:52 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: starting problems
Sounds like a cold start problem. I'm not sure but does TPI have cold start injectors?
Old 12-27-2003, 12:34 PM
yes i heard they do have a cold start injector the 9th one
yea and im new how do i get my pic of my car on here like urs
Old 12-27-2003, 03:42 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
um, whoa, what year is it, because if its an 89 or newer, it dont have the 9th injector, it has cold start enrichment programmed into the computer for longer pulse width. 88 and earlier has the 9th injector. im having the exact same problem with my 89 IROC, could be any number of things, here is what im looking at thus far, ill let ya know if anything pans out.
-IAC valve
-MAF sensor
-ICM
-PCV
-Ignition coil
i also have no codes, but hey, you might as well check your car to see if you have any. if you dont know how, ill be happy to post how to do it, or someone else will probly beat me to it
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-27-2003, 03:43 PM
89IROC&RS's Avatar
oh and to put a pic up, you have to go to the gallery place on this forum, and post a pic, then click on the picture you just posted, and copy the link location, and put it into your signature which you can find in your control pannel, once the link is in, it will show up in your sig every time you post.
Old 12-27-2003, 10:18 PM
Did you ever figure your problem out Iroc?
Old 12-27-2003, 11:33 PM
no i havent yet still looking
Old 12-27-2003, 11:55 PM
bboyz28 bboyz28 is offline
Send a message via AIM to bboyz28 Send a message via Yahoo to bboyz28
Hey are you a Rocky fan? (The Rock)?
Old 12-29-2003, 11:43 PM
use to be long ass time ago not really anymore
Old 12-30-2003, 09:21 PM
89IROC&RS's Avatar
naw, havent had alot of time, and cant get the IAC valve out to look at it, socket wont fit, and wrench wont fit, ill have to take the throttle body off to get to it. see if its bad or just needs cleaning. i did do a test on it, and if i did the test right, the IAC is bad, but then again, it could just have a blockage, or a build up on it and just need a cleaning. but untill i pull it, cant say for sure. so thats a saturday project.
Old 12-30-2003, 10:34 PM
Gotta love them Saterday jobs huh?
Old 01-01-2004, 03:28 PM
89IROC&RS's Avatar
absolutely, although it got bumped, i got better projects, taking ashleigh out for a photoshoot, and then leah is coming in from her european vacation that evening, then the D.C. carshow so the IROC got bumped, ah well. life is so hard.
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 06:56 PM
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 05:04 AM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 12:13 PM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 08:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
