Old 12-27-2003, 01:54 AM
95GSTRaCeR 95GSTRaCeR is offline
Exclamation 95 Eclipse Turbo Problems
Okay, this question has probably already been asked, but I have been searching endlessly through all of these threads and different websites, but still cant find an answer so i'm gonna ask.
I have a 95 eclipse GST, when I first got it there were no modifications at all. The problem is when I am going down the highway and I punch it the turbo will climb to 5 psi and start shaking (more of a sputtering or kind of like it is tripping over itself) if you let of the gas and then ease into the boost the most it will hold is 7 psi, on a good day, normally it can only hold 5 though,but even when you ease into it then punch it it will start having the same problem. I have asked numerous people what they think it is and had them drive the car. Two people said that they thought there was something wrong with the fuel system. So I replaced the fuel filter and I put in a Whalbro 255 fuel pump, but i still have the same problem. When I first got the car it could hold close to 9 or 10 psi, but it is gradually getting worse. Since I got it I have put in a HKS Super Sequential BOV and a manual boost controller. I have tried tons of stuff and I cant figure out what is wrong with it. One website told me to check for boost leaks but I cant find any. Any help or ideas you have would be greatly appreciated.
Old 12-27-2003, 02:41 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
yea it most likly it is your fuel system, it almost sounds like you have a clogged injector or possibly more than just one... also what did you do when you checked for a boost leak? on www.vfaq.com they show how to make a boost leak checker to hook up to an air compressor, then spread soapy water around your connections and pipes to and from you IC and your manifold... if that doesnt work, while the car is running try spraying starting fluid around your manifold to see if that has any leaks, if your car increases RPMs you found your leak, but from the way you said the engine is acting it doesnt sound like the manifold is the problem but just incase. but yea it has to be a boost leak or fuel related from the way it sounds... so double check just to make sure good luck
Old 12-27-2003, 02:45 AM
I used soapy water to check for leaks. Thanks for the info.
Old 12-27-2003, 02:47 AM
Re: 95 Eclipse Turbo Problems
one thing I forgot to mention was that I was talking to a mechanic and he said he thought that my turbo might be going out, does anybody think there could be any truth behind this, any ways to tell if your turbo is going out?
Old 12-27-2003, 02:50 AM
EclipseRST's Avatar
Banned
but did you use the home made compressor adapter, see if you didnt i would try that cause a compressor has on average about 120-130psi, now its goin to be easier to find a leak that way instead of reving the engine to build psi to check for bubbles! plus 120psi compared to 5psi, hmm you should atleast try it if you havent already! good luck
Old 12-27-2003, 02:52 AM
good point
Old 12-27-2003, 02:56 AM
EclipseRST's Avatar
Banned
Re: Re: 95 Eclipse Turbo Problems
does it have a lot of shaft play in it? to cheak just take off the intake pipe that connects to the turbo and grab the propellar and try to move it around... if it moves a lot its not good! also what turbo is it? stock? the only other think i can think of is when you take the intake off look at the blades to see if any are missing or beat to hell!
Old 12-27-2003, 03:07 AM
the turbo is stock with 112,000 miles, i also had the whole turbo system cleaned out at 106,000 miles when i bought the car hoping it would fix the problem, no luck, but i will check for the shaft play and see if anything is broken. do you think these things could be causing the problems?
Old 12-27-2003, 03:15 AM
EclipseRST's Avatar
Banned
if the shaft play is really bad and doesnt spin right it can cause bad turbo lag... cause instead of moving freely if its got a lot of shaft play and starts to move up and down and back and forth, its gunna cause resistance on the shaft causing it to lag or move slower!
Old 12-27-2003, 07:43 PM
I took off the intake pipe and there were no bad fins and no shaft play but the intake pipe was caked with what appears to be really black muddy oil. Any ideas why?
Old 12-27-2003, 10:22 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
that is because of the valve cover return line. notice the hose going from the valve cover to the intake? bingo. you can get an oil catch can or make your own. how long have you had the boost controller? have you tried to turn it up? you should be boosting more like 15-16 psi. yes, your snail is old. but when it spools up does it sound smooth or does it sound like it's screaming (screaming is a sign of shaft play, think smooth vs wobbling spin)? also, venting your BOV is not the greatest idea. do a search about that. basicly, the ecu is designed for a dump set-up, so by venting it, your ecu gets funny readings from your MAS, affecting performance. that said, be sure that your BOV is working as advertised, if you have your old one, you may want to hook it back up, dumped of course, and see if the problem persists. hope that helps
Old 12-27-2003, 10:44 PM
I dont think that the problems I am having could be because of the BOV because it was having the problem when it was bone stock, but I may be wrong. With there being no shaft play and the fins in good condition any other ideas why I am having this problem?
Old 12-28-2003, 04:23 PM
Re: Re: Re: 95 Eclipse Turbo Problems
did you try this? what kind of boost gauge do you have? is it working right?
Old 12-28-2003, 05:22 PM
I did try turning the boost controller up and all that I can boost is up to 5-7 psi and then the car will start to jerk. As for the boost gauge it is a Type-X. I am sure that it is accurate. At idle it sits at 20 INHg. Is that where it should be?
Old 12-28-2003, 08:08 PM
it should be on the vaccuum side [counterclockwise], i got a GReddy gauge and it measures in MM of HG, but it sits just above the 500 mark, you can do the conversion... this is really starting to sound like a misfire problem. what kind of spark plugs and wires are you using? the 4g63 is very tempermental about this, and with the amount of usage on your motor it may be this. like a wire that is getting worse and worse. the stock plugs and wires are the best choice, take 95gsxracer for example...
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
eclipse 97 gst convertible - turbo problems? bluesockets Engine, Transmission and Drivetrain 2 01-06-2002 09:46 PM
eclipse 97 gst convertible - turbo problems? bluesockets Engine, Transmission and Drivetrain 0 12-27-2001 08:55 AM
eclipse 97 gst convertible - turbo problems? bluesockets Engine, Transmission and Drivetrain 0 12-27-2001 08:54 AM
