Old 12-26-2003, 09:55 PM
SAM12361 SAM12361 is offline
fuel pump help
need help on how to check/replace my fuel pump
4.3 liter "w" 1999, CHEVY ASTRO VAN
I do not hear the pump cycling in tank also removed fuel filter and turned on ignition no fuel at the lines under the van.
is this thing dead can i jump it out at relay and be sure it is bad
thanks big al
Old 12-30-2003, 12:04 AM
ANY BODY OUT THERE
Old 12-30-2003, 05:18 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: fuel pump help
If you can get to the wires at the tank that feed the pump, use a test light between the gray wire and ground..have someone turn on the key, the light should light for 2 seconds..then have them spin over the engine..the light should stay lit..if so the pump is bad
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-31-2003, 10:02 PM
Busted 4.3 Busted 4.3 is offline
I always start with the obvious, and cheapest possibilities
Did you check the fuel pump fuse ? Of course if it is blown, then you will need to find the short that blew it, which of course could be the fuel pump
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
