Old 12-26-2003, 04:51 PM
Colov99's Avatar
Colov99 Colov99 is offline
Send a message via AIM to Colov99
Cool Project Puprle Haze
so what do you get when you have a v6, a blitz body kit, lambo doors, and a open trunk,
this:
right now its in the cutting stage, i have the doors cut out now. in the pic the body kit is just taped on. kudos to Chris @ SAS for quality. ill hope to get more pics up, im thinking of a purple/silver paint for the eterior. and some other mods
hopefuly more pics to come, i should get alot done before i have to head back to college.
Old 12-26-2003, 05:37 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Project Puprle Haze
V6? I've seen the 3.0L Stealth twin turbo in the Integra Type R once, but why?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-26-2003, 05:41 PM
Colov99's Avatar
v6
no its a v6 from an nsx, a bit more power still managing to keep it FW drive.
the reason, cause no one else has and its a bit more HP
Old 12-26-2003, 07:13 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Re: v6
I built one that was probably capable of putting down alot more torque and power at the rear wheels than that nsx motor ever would. Looks good, might I suggest for your paint, lay the purple down all over the body and just fade silver from the bottom of the body half-way up.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-26-2003, 07:16 PM
Colov99's Avatar
well i was thinking of laying down the purple and lightly spraying some silver over it.
and what motor did you put in?
and i like the NSX motor because its N/A (normaly aspirated). i like motors that do power with out those extras.
Old 12-26-2003, 07:22 PM
86_SR5's Avatar
That's the paint scheme I was talking about just let whatever over spray be and that can be your fade.
The chassis was chopped up and I built new tunnels for a rear end, and transmission. The motor I used was a 90 something or other LT1 corvette transmission, with a T56 6sped manual. It fit quite well, only thing was I had to add mega rear wheel camber because the car looked 5 scale inches higher in the rear. But this year coming, I'm going to make a turbo typeR AWD track star. and still retain the VTEC motor, and transverse motor mounts. Staytuned, as it's coming in a week or two!
BTW, could you post some pics of the motor in the engine bay when you get it fitted?
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-26-2003, 07:38 PM
Colov99's Avatar
sounds prety good, ill try to get pics up as i do it, i can say it wont be the best swap ever since its my first but ill do the best i can for it. im hopeing to have all parts cut for the lampo dors and rear hatch soon. so maby all the body work done sometime next week to get ready for spraying. ill try to keep this updated.
Old 12-26-2003, 07:41 PM
86_SR5's Avatar
Cool, just take your time. If you don't have time to do it right, when will you have time to do it over? My dad used to say that all the time when I was kid and he'd build his kits.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-26-2003, 08:02 PM
Colov99's Avatar
if i realy have trouble with it then ill just leave it till my next break from school (spring break), or the summer when i have even more time. im hopeing to get a chunk done soon (the exterior) but if it takes longer i dont mind taking my time.
heres a pic to show the body kit in its semi mounted (some touch up and gluing still needed plus filler. and to show that i took the doors off.
Old 12-26-2003, 08:15 PM
86_SR5's Avatar
that's cool. Might I suggest the grey 7spoke rims, instead of those, just a thought.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-26-2003, 08:23 PM
Colov99's Avatar
ive thought about that but im not sure i like those very mucn, what i really need is like 10 spoke wheels but ill see whta i can get. i just dont get the right vibe of those 7 spoke but ill try to get a pic up of the car with those on for comparason
Old 12-26-2003, 08:24 PM
86_SR5's Avatar
Or, if you have an LHS, they sell XS Tuning, 17'' wheels. They have a variety of styles and colors, you could allways check them out.
EDIT:
BTW, how do you make your pics smaller so they fit on the AF web gallery?
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 12-26-2003, 09:19 PM
Colov99's Avatar
here it is with the 7 spoke rims, and my camera has a function that does 640X480 so i dont need to resize it. other wise just use an image program that should work.
Old 12-26-2003, 09:29 PM
86_SR5's Avatar
Yea, I figured that out. Looks cool, but I don't know now. Is this going to be like a street performance car? Because I have another suggestion for the wheels if you're doing street/performer. The 5spoke rims, useing a fine brush, brush some metallic, or gloss black right on to the spokes, leaving the lip chrome, that'd be pretty cool I think. But It's your car, your build. BTW, check out my latest threads "CSM 55'Chevy and 64' Dodge 330" and "Fujimi Drift Machine".
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
'97 Civic project Metal_Crue '96-'00 Civic 1 10-26-2009 02:26 PM
