Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-26-2003, 01:19 PM
BK1 BK1 is offline
Valve cover
Hello all,
First timmer here, and am going to replace the valve cover seal/gasket on my 96' SL2. My question to those who might be in the know. Do I need to torque them down or just tighten, and I if need to torque them down, at what lbs.?
Great site, will have to visit here more! Been upgrading the Montero Sport with my time and $$$ right now.
Old 01-03-2004, 12:29 AM
fifer fifer is offline
Re: Valve cover
do not torque them down, you will probably break the bolts like I did. just tighten them down until they are snug, if you try to give it a last 1/4 turn you are likely to break the bolt heads off.
Old 01-05-2004, 04:16 AM
wolfmanS wolfmanS is offline
Send a message via AIM to wolfmanS Send a message via Yahoo to wolfmanS
Re: Valve cover
Torque spec is 8ft pds.
Old 01-17-2004, 09:08 PM
VS1400 VS1400 is offline
Re: Valve cover
I believe the spec is acutally 89 inch/pounds. It's a good idea to torque them because overtightening them can lead to disaster. It is easy to strip the threads in the head out if overtightened.
Torque the bolts around the plug holes first.
If you're having trouble with oil seeping onto the #1 or #2 plug, do yourself a favor and use a little sealer on the rubber gasket before installing.
On the black plastic valve covers, leaks can sometimes be caused by warping in that area and some engine sealer around the plug hole can help prevent it from re-occuring.
Polished Valve Cover for sale Axelthered05 Classifieds 0 06-22-2009 02:09 PM
timing belt covers/valve covers 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-30-2004 08:16 PM
3.0 V6 valve job/valve cover gaskets 1988 VTISC007 4Runner/GX470 2 03-02-2004 10:21 PM
Valve cover color? G22DET General 43 01-08-2002 02:33 PM
