Old 12-26-2003, 07:48 AM
s10frameoff1993 s10frameoff1993 is offline
Send a message via AIM to s10frameoff1993
Clutch Problems
93 S-10 P/U, 5 speed, 2wd:: The whole clutch assembly is new - in the tranny and the slave cylinder and clutch master - it's all new. I just can't get the thing to bleed now. I've tried for hours, and can't get it done. Friends told me there could be a leak. Every part of the system is dry. A manager at AutoZone told me that the clutch plate tangs, where the bearing pushes in, could be sticking in and not coming back out, keeping the clutch engaged. And my clutch is staying engaged. It worked once for me and then about a week later, it didn't work. Any ideas?? I can't seem to find anyone that has an answer to this. This truck has been off the road for over 3 1/2 years without running. Now, it runs mint, but I still can't drive it. I want to drive it now...Please help. Thanks.
~CS4LIFE~
www.csautoclub.com
Frame off on a 93 S-10 Pickup
Bagged & Layin' Frame
Chassis Is Molded And Painted
Suspension in ENTIRELY Chromed
Engine is Painted & Chromed
Polished Fuel Cell & Braided Lines
Stainless Steel Braided Brake Lines
"The more chrome the better"
Old 12-27-2003, 09:43 PM
tom3 tom3 is offline
What actually happens when you push on the clutch? Do you get a normal feel? Any chance the plate has rusted to the flywheel. This is very common when they sit for a time. Push on clutch and have someone rock truck back and forth with it in gear to break loose. Bleeding is simple, just open bleeder at slave and push down on pedal and close bleeder while fluid is still coming out. Don't let up on pedal with bleeder open.
