Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-19-2001, 10:29 PM
khead717 khead717 is offline
raise car higher than stock?
Will i be able to raise the car higher than stock if i get coilovers? i need to do it because a cop asks me to and if i don't , i guess i am going to pay the fines or go to jail or something...........so help...
Old 12-19-2001, 10:36 PM
jdmakkordman's Avatar
jdmakkordman jdmakkordman is offline
Send a message via AIM to jdmakkordman
higher than stock no....stock or very close to it? yes
whats po po's problem?
Old 12-20-2001, 12:46 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Depends what kind but I doubt it, you may be able to get close to stock.
The reason is 99% of the springs are shorter than stock, and the shock rods are shorter too.
M.Sanew - AutomotiveArticles.com
Old 12-20-2001, 12:59 AM
cause i lowered my car and got a ticket. and the cop wants me to raise it, and i did raise it back to stock height, but he said it's still not high enough. he said it has to be a inch or two higher.....i don't know what else to do...
Old 12-20-2001, 01:01 AM
Mod for life
24" ground to fender that is where you need, it
how low are you?
Old 12-20-2001, 08:49 AM
Goosse's Avatar
Goosse Goosse is offline
Send a message via AIM to Goosse
Are you sure this guy is for real? I don't think they can do that without a valid reason. What is illegal about lowering a car
Old 12-20-2001, 07:21 PM
and why does the cop hate you? buy him donuts
Old 12-21-2001, 04:07 AM
the cop measured from the ground to the center of the headlight lamp is 21" . He says it has to be at least 22"...@@
Old 12-21-2001, 05:42 PM
b16a2si's Avatar
b16a2si b16a2si is offline
Is this law enforced only in CA???
Old 12-21-2001, 11:25 PM
Twainturbo Twainturbo is offline
i dont know if this law is ONLY enforced in cali, but it sure is enforced, cops are at their worst when dealing w/ tuned imports here, they will get you HARD for below legal limit and window tint....always window tint. you are correct about the 22" limit, although i find it hard to believe that you can't raise it up that high again, i had a civic that sat LOW on coilover sleeve and i was 21" to center on about a 3'what coilovers are you running? did the cop eyeball it or use something to square it? did he do it on level ground? all these factors can affect his measurement, and one inch is an easy margin of error to f#ck up. the reason for your headlight level is for other drivers to p/u your headlights while following, below 22" is too hard to see unless you increased your following distance. anyway, just understand your rights and make sure the cop is measuring your ride correctly and not just trying to screw you over because you are in a rice rocket, and tell me when the last time a cop pulled over a classic muscle car for being too low or too much tint was and that may explain your dilemma. G/L man
BOOOST!!!
Repprezzent...
Old 12-21-2001, 11:30 PM
sorry for the double post but i meant to say that i sat at almost a 3" drop sometimes on my civic and i was at 21" to center of lamp, so if you raise it to stock or near you should be just fine, go to home depot, buy a measuring tape and torpedo level and do this,
on level ground, measure up to your headlamp center and use the level to level a straightedge across the center of the lamps so that you KNOW you have a true measurement, and then educate officer estrada on your newfound light on life
and give him one of these:finger:
BOOOST!!!
Repprezzent...
Old 12-22-2001, 03:21 AM
i already have stock springs on, and i measured from the ground to the center of the lamps and it's 21". maybe i'll put my stock rims and tires back on...but i doubt that's gonna help.....
f...if i can't get my car 2 inches higher then i am going to jail...
Old 12-23-2001, 11:13 PM
petzride's Avatar
petzride petzride is offline
go jail for that???? u need a lawyer.......
FULL OF S15~~
For sale: http://www.automotiveforums.com/vbulletin/t53308.html
Old 12-24-2001, 03:29 AM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
This is the law for Oregon, I like it.
Minimum Clearance
No part of the passenger vehicle can have less clearance from the road than the lowest part of the rim on any wheel.
So basically, if you have 35 series tires, then you can be about an inch of the ground legally.
Old 12-27-2001, 10:02 AM
Quantum2+2's Avatar
Quantum2+2 Quantum2+2 is offline
Thank God I dont live in the U.S.
In the U.K. the cops dont really bother about how low your car is providing it doesn't scrape the road and there is clearance to get over speed-humps etc.
As for the height of the headlamps. OMG they only bother about headlamp aim and direction and not height.
I like being in the U.K. with some of the rules you have to put up with in the U.S. for your cars.
Mercedes C250td elegance
Quantum 2+2
Won't turnover using Viper Car starter if it's higher than 85 outside! 2talll Explorer | Explorer Sport Trac 0 06-12-2005 03:56 PM
New Fuel Economy Proposal Could Raise Costs More Than A Gas Tax Bruce Levinson Cars in General 0 01-09-2004 05:22 PM
Is rear higher than front normal? khead717 Tires and Wheels 15 12-12-2002 12:15 AM
Do I need alignment if i raise my car back to stock? khead717 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 12-06-2001 05:15 PM
higher than normal idle agthang Maintenance 2 04-02-2001 07:53 PM
