wiring diagram for a 2000o neon
just recieved a remote start for the neon, any one know where I would find a diagram to install this to the car... any help would be greatly appreciated. I installed the on on my avenger... but have forgooten where I found the diagram...
Thanks Clint |
Re: wiring diagram for a 2000o neon
dunno if you got your answer yet but the Haynes manual, located at your nearest parts store has an entire layout for you.
Just like on a brand new T&C minivan, it will not tell you which wire to tape nor will it tell you what resistance to ground you need for the doorlocks to work and also have the alarm disarm.
well if he bought a remote start, if it is a good one, it should have the installation instructions with it. That will tell you all that mumbo jumbo all he needs is a wiring diagram to tell him where the asked for wires are located, if he did get instructions with it. If you look in the Haynes it does give you a wiring diagram.
For example. Wire A goes to wire A. Look in haynes manual for color wire "A" and find it in car and presto!
point taken. Then what remote starter is good and has detailed instructions specific for the Neon?
Wiring Diagram for Neon 2000
2000 Dodge Neon Security Information
Constant 12V+ Pink/Black or Red Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue Ignition Switch Harness Ignition 2 Black/Orange Ignition Switch Harness Accessory Black/Orange I gnition Switch Harness Tach Black/Gray Coil Neutral Safety Wire Yellow (+) Ignition Switch Brake Switch White/Tan Brake Switch Trunk Release Green/Black (+) Driver's Kick Panel Trunk Pin Tan/Black (-) Trunk Light Parking Lights Black/Yellow (+) Light Switch Head Lamp Purple/White (+) Light Switch Door Trigger Light Blue/Orange&Tan Driver's Kick Panel Door Lock Light Green Single Wire Negative Trigger Door Unlock Light Green Double Pulse 1.5K Driver's Lock Orange/Black (+) Driver's Kick Panel Driver's Unlock Pink/Black (+) Driver's Kick Panel Passenger Unlock Pink/Purple (+) Passenger's Kick Panel Horn Wire Black/Red (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White Windows Down LF=White/Light Blue, RF=Purple/White |
