SOHC ZC Compression
Does anyone know what the compression ratio is on the stock SOHC ZC motors. I'm trying to figure out what the CR will be once I put the d16y8 head on it which also depends on the headgasket type I use. I found a link that calcualtes the CR but I'm not sure if I should calculate using the d16a6 pistons or the ZC pistons cause it doesn't specify if it is for a DOHC ZC or SOHC ZC. Check it out at http://www.knology.net/~jediklc/D.htm
On MPFI SOHC ZC it is 9.1:1
On Dual CV Carb SOHC ZC it is 9.3:1 |
Re: SOHC ZC Compression
Thanks for the numbers. Where were you able to find this info ?
From official honda website info, when I was sourcing myself a SOHC ZC...
http://www.honda.co.jp/HOT/ModelData/ Use this to translate... http://babelfish.altavista.com/babelfish/tr |
