Help!!! Stuck Key
I cant get the key out of my passport. I can start it with no problem but I cant get the key out. I check all of the fuse but they are all ok.
Help!!! |
Its 98 Passport
you do have it in park right?
My other ride..... is YOUR MOM !!!!!!
Re: Help!!! Stuck Key
By Car I Mean Honda Passport I Gave Her The Same Rediculous Remark You Got Cliffcon Sorry About That It Seems Silly Until You Have To Deal With It Yourself.
Its fixed. I end up putting a lot of grease at the shifter links and have to bent the cable holder in the ignition key switch. The plastic mechanism in the shifter is a weak design.
To get it out with out taking out the panel. Once the car is on park, push the shifter button and let your tumb slide down so the button snaps back. This should get you key unstuck. |
Thanks for your help Cliffcon. I'll let her know ass soon as I can. Hopefully this helps anyone else out there looking for help with there key stuck.
oops I'm really not going to let her ass know. I'll just tell her face to face, or maybe over the phone
Sorry bout the typo Mr. Moderators
Try a little powered graphite in the lock mechanism, it acts as a lubricant
gunnmen01
THANK YOU! |
ill have to keep that in mind if i get one thats stuck at work... thanx
gunnmen01
stuck key me too
key stuck in ignition? the replies you got are all helpful and may get your key out temporarily but it finally will be stuck there forever unless: you replace the ignition in the steering wheel. Apparently this is a somewhat common problem with this particular car. I have also replaced two electric window regulators, but I still love my car.
replacing the ignition switch will also mean a seperate ignition key, unless you get it rekeyed... but you dont need to replace the ignition switch
