Old 12-24-2003, 07:12 PM
YaGSX YaGSX is offline
Send a message via AIM to YaGSX
to bore or not to bore
My question to all the dsm gurus out there is wether or not boreing the engine to a 2.3L is worth it on a turbo engine, i have some work done so far turbo back exhaust, boost control, flywheel and clutch and it seems i have a bad head gasket so I am leaking coolant, i though as long as im pullin the head off, instead of doin turbo work, mite as well get the motor redone
Old 12-25-2003, 12:06 AM
ok so ur sayin go with a new motor all 2gether, but will the new 2.4L shortblock now be able to handle as much boost? if not what would be better little extra displacement or stock motor with more boost
Old 12-25-2003, 01:29 AM
stupidsm's Avatar
stupidsm stupidsm is offline
Send a message via AIM to stupidsm
Re: to bore or not to bore
I always hear my buddies talking about boring like .2 over because it makes the turbo spool faster. If you want some names of guys who are good with this stuff let me know and I can get some to you.
Free @simplyspeed.com email addresses
www.simplyspeed.com
Old 12-25-2003, 02:21 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
ok now it all depends on who is doin the work, i know you said that you had a bad head gasket, now are you removing everything yourself, if so then i would just bore the block and if you want to make it a 2.4, get a stroker kit, thats what my plans are for my winter project... plus i do believe that they dont swap easily, meaning modifications are needed. also it will be cheaper to do the bore and stroker kit instead of buying a 2.4 and puting it in the car! as of right now my block is bored .020 over and i have no problem reaching boost and holding it at 21psi, even on a 420a!!! good luck, let me know if there are anymore questions that i can help you with.
Old 12-25-2003, 09:56 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
an If you know what you doing
I still trying to see how you Blame .020 over for blowing your engine
-Agim
Old 12-25-2003, 03:05 PM
ya that would be great to get the names and numbers of any guys who are good with this kinda stuff, especially if theyre in the chicago area, also i just wanna make sure i know wut im doin, so bore out the motor .020" and get the stroker kit and im in business, this will make for quicker spool and little more displacement power, still run as much boost as i want, but it could get risky when im running really high boost, all for a grand price of round 3 grand would u say? i was also thinking of converting to a 6 bolt crank and all that
Old 12-29-2003, 02:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
You need a 6 bolt block to go to the 6 bolt creank. If you are going to do a 6 bolt swap, its not much more work to do the 2.4 lite swap at the same time. If you cant find one, or just want to convert to a 2.3, just get the 2.4 crank, eagle or other 6 bolt rods, and ross or weisco stroker pistons (pin is moved up 6mm). Boring out the block doesnt do much for displacement. It should only be done to get the cylinders round again, and to get a good ring seal (the whole point of a rebuild). But for what its worth, a 2.0 and 2.4 use the same casting, and the bore is .040 over the 2 liter bore and the 2.4 still runs 9s in marcos car. And poeple usually bore the 2.4 another 20 over in the build up.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
