Old 12-19-2001, 09:23 PM
89ssgti's Avatar
89ssgti 89ssgti is offline
Question Brake ?
Ok,so today I did a brake job on a f350 2000,I know it ain't a Honda but it's a tech question anyways.And I found the caliper placement on the rear axle to be weird.As there is one on the backside(the right one) and one on the frontside(the left).
Could somebody give me a valid and logical explanation to this,because all the other rear disc brake I remember having seen,the caliper was positioned at the same place on both sides.
Thanks in advance guys.
Old 12-19-2001, 10:56 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
I don't know, but I will find out. I suspect because of space issues. In general, other then weight distribution, it doesn't effect braking performance wear the caliper is mounted. I bet there is something important in the way of the line or caliper that made them decide to mount the calipers in different locations.
Old 12-20-2001, 12:39 AM
89ssgti's Avatar
It's not really a space issue as it is a full size pick up,and there is really nothing in the way.It could even have two caliper per wheels as far as space is concerned.
The only thing I can think off is that it enables them to use only one caliper for the two sides(like in the same part number).
But I don't think it's the only reason.
Does caliper placement affects the way the brake system react or change the vehicule dynamics under braking?
Old 12-20-2001, 12:59 AM
Same part of both sides... I wouldn't put it past Ford; They've done some crap like that before. For example the last generation T-bird had a nicely designed uni-directional vented disc... But they only had one of them... So one was on backwards... Nice eh?
But in this case, a lot of other parts would have to be changed in order to use the same caliper on each side, and since the calipers are farmed out anyway I don't think that is the reason.
Actually it doesn't. The placement of the weight of the caliper can make a difference, but in a 3 ton truck with a huge (HUGE) rear axle and differential I don't see it making that much difference. My bud, who is a mechanical engineer and a huge Ford Truck fan will surely have some insights into this. I'll see what he has to say on the subject.
Old 12-20-2001, 01:08 AM
89ssgti's Avatar
Thanks man,I appreciate it.
Old 12-21-2001, 07:03 PM
89ssgti's Avatar
So Someguy,any news and explanation I could use ?
Because it's really bugging me, I think about that on a daily basis.It's a joke, but I really want to know.And if you had any news from your friend, I would like to know.
Thanks for your help.
Old 12-27-2001, 09:10 PM
89ssgti's Avatar
ttt
Old 12-27-2001, 11:22 PM
I talked to him and he didn't know. Apparently they start doing it that way until the latest model. I talked to a few other people that are into those trucks, and they sugested everything from better control under braking with a heavy load, to the saved cost of only needing one bracket.
So, basically, you've got me.
Old 12-28-2001, 06:26 PM
89ssgti's Avatar
Thank you for checking.
2002 OHV 3.0L Lack of power, stiff brake pedal Ruley73 Taurus | Taurus Wagon 7 03-05-2011 10:49 AM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
The Brakes the Brakes the Brakes are on Fire!!! Neutrino Street Racing 14 04-24-2004 02:29 PM
Brakes, Brakes Brakes hondaman-iac Accord/TSX/Accord Hybrid 0 08-11-2002 10:08 PM
