MPFI swap problem
Hi,
Just fixed the gas leak problem on the SI manifold. Well, i hooked up all the hoses and doubled checked everything. Started it up took quite a bit of cranking but i finally got it going. It seemed to idle fine I didnt wanna drive it quite yet. Anyways, I let it idle for about 5 mins and then shut it off. I checked my ECU and im getting only one code- Code 4 I know this is for the Crank Angle Sensor What should i check. Also, anyone got a good pic or diagram on how to set up the vacumm hoses from a DX to a SI manifold? Thanks
1990 Honda Civic LX 5 Speed 1.5 Liter SOHC K&N Cone Filter APC Short Shifter 1988 Honda Civic STD Hatch |
Re: MPFI swap problem
the crank angel sensor is in the distributor on the si but not the std did you use the si distributor?
sorry no camera to take a pic of the vacumm lines |
Yea, i used the SI dizzy.
I followed all the directions as best i could. The car starts and idles good. But im still worried about the code 4. The car really smells of fumes and I dont know if this has to do with it. Any other ideas. Its the only code im getting. What could I have got wrong while doing this MPFI swap? Thanks
Yeah.. Did you use the Si distributor?
There should be 2 extra wires coming off it Did you used good quality shielded wire for these? I have heard of people correcting this problem by changing to a higher quality wire from a cheaper one ... I don't know if this was really the fix... or bad connections or what.... |
Yes, i have also heard of using shielded wires.
Quick question: If the car starts and idles does that mean I can rule out the wire depining in the ECU? Cause thats what Im kinda worried about. Also, what kind of shielded wires can I use? Thanks
I searched all the past MPFI swap threads and found someone with the same problem getting a Code 4.
He said the problem was in the B area of the swap. Im assuming he meant moving the B wires to their appropiate locations. That is the thing I am worried about. But I doubled checked it and it looked good. Thanks
Don't know if this will help or not ... as some of the tutorials/howto's are a little confusing.... but this one seems rather well written.
http://www.fourthgenhatch.com/mpfi.html |
