Old 12-24-2003, 11:02 AM
michaelmeck michaelmeck is offline
700r4 lockup?
I read a while back about how to put in a switch to make your torque converter lock up sooner, but can't remember how to do it now. I would like to try it out just to see how well it works I know it had something to do with grounding out a terminal somewhere?????
Old 12-24-2003, 11:10 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 700r4 lockup?
? i would imagine you ground out the TCC switch. or supply power to it, im not sure exactly how it works. im interested to hear about this.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-24-2003, 11:53 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: 700r4 lockup?
Doesn't it already lock up at 1200RPM? Do you have enough torque below that to get you going?
Old 12-24-2003, 12:33 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: 700r4 lockup?
The lockup clutches won't normally lock up unless you are under a constant acceleration for a while, like when running in OD on the interstate. It can be at any rpm.
This mod won't lock the TC up while in 1st gear, you have to be in 2nd or above.
Here is what you do, and yes, I know for a fact that this works...
You have an ALDL connector under your dash. It is the diagnostic connector thingy...
1. Get some wire, and a switch.
2. Mount the switch wherever you want to.
3. Run a length of wire from each terminal of the switch that is long enough to reach the ALDL connector.
4. Strip about 1/2 of sheathing off each wire.
5. Insert 1 wire into terminal A, (the top left), and 1 into terminal F (the top right).
6. Now just flip the switch to engage it.
7. To test, start with the switch on, from a stop, drive normally, when it shifts to 2nd, you'll feel the engine bog a bit and the rpms will come down, just like in a stick. You should be able to then pop the gas and feel it jump because of the direct link between engine and tranny.
Enjoy...
My Project Write-Up
Old 12-25-2003, 06:21 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Be careful doing that because the clutches in a lock up converter are not made for 100% of the power going to them. Us turbo buicks guys use this trick alot and it works but it's hard on the torque converter. I used to do it, mine was setup just like red hot z said but I don't do it anymore. Iv'e already distroyed one torque converter
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-25-2003, 10:48 PM
Re: 700r4 lockup?
That is interesting. could you rebuild your tranny with some really good clutches and such for it not to be so hard on the tranny?
Old 12-25-2003, 10:56 PM
89IROC&RS's Avatar
Re: 700r4 lockup?
well, the clutches in the tranny would not be the problem there, its the clutch in the converter, you would have to talk to like B&M and ask if the converter would take it. that setup wouldnt hurt the tranny at all, but could eat up converters easy, i would imagine the converter would still work, just never lock up. and yes, in stock applications the converter only locks up in fourth gear after it senses the right conditions, speed, rpms, engine load, so on and so forth. so my question would be, if you have the switch on, so that it locks up in 2nd, when you leave in 1st, your on a regular setup, and then when it shifts into 2nd, it locks up immediately, and stays locked up in 3rd, and 4th? has anyone tested this at the track and seen improvements??? i really like this idea, very curious.
Old 12-25-2003, 11:23 PM
Re: 700r4 lockup?
I've heard it'll gain ya about a tenth in the quarter and up your trap about 2mph...
My Project Write-Up
Old 12-26-2003, 02:13 PM
Re: 700r4 lockup?
I have a stand by converter incase mine grenades so I will give it a try and let all of you know how it turns out
Old 12-26-2003, 04:46 PM
Hypsi87's Avatar
Re: Re: 700r4 lockup?
It gained me about .2 thens and about 2 MPH in the qtr. When your clutch goes bad in the converter you will have to do a complete tranny flush. clutch dibris and other stuff gets into the fluid. Art carr makes a converter that has a five disk clutch that can take the abuse but I think it is over 1,000k just for the converter.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 12-26-2003, 04:52 PM
Re: 700r4 lockup?
Holy shit that better be one hell of a converter. But again, that sounds like a pretty nifty thing to do. If I had any kind of money to put into a new converter then I'd try it.
Old 12-26-2003, 05:00 PM
Hypsi87's Avatar
I would think that I would spend 1k on more power to make the extra HP to gain 2 tenths and 2 MPH
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 12-26-2003, 05:33 PM
Re: 700r4 lockup?
I agree, but hey if you got the money to burn then go for it.
Old 12-26-2003, 07:26 PM
89IROC&RS's Avatar
Re: 700r4 lockup?
yeah that converter sounds like a race application for every possible advantage. but yeah that sounds pretty cool. ill have to put that in my little notebook of tricks, if i need that last .2 seconds to break into the 10 second relm
Old 12-26-2003, 11:07 PM
Re: 700r4 lockup?
Hmmm...get a manual/automatic tranny. Works like a manual when your stopped and an auto when your going. Yeah..that's the ticket.
Poor transmission lockup robbie_NH Roadmaster 3 07-07-2009 07:14 PM
700r4 no lockup GreyGoose006 Caprice 13 07-30-2008 04:20 PM
2000 Trailblazer hard shifting and no torque converter lockup mikeym2m Blazer 4 03-01-2004 11:54 AM
Lockup Converter Disable davisa Regal 6 07-20-2003 07:05 PM
4 wheel lockup Sudsy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 09-10-2002 09:18 PM
