Old 12-24-2003, 09:53 AM
blade34609's Avatar
blade34609 blade34609 is offline
Fuel Pressure Regulator
Hi,
I finally got my SI intake manifold on and was about ready to start it.
I turn the ignition to on (not to start the car) and my bro says shut if off.
I shut if off and gas is shooting out of the fuel pressure regulator.
I thought maybe the bolts wernt tight enough but that wasnt it.
I took the pressure regulator off and found that there was no O Ring to seal the fuel. I hate it when you buy shit off Ebay and parts are missing.
Anyways, heres a pic http://www.binghamtonlife.com/manual.../91-11-107.jpg
Im gonna take the regulator to Autozone and get a replacement one.
It should stop the leak right?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 12-24-2003, 01:27 PM
BullShifter's Avatar
Re: Fuel Pressure Regulator
Yea, the o-ring is a seal. What would happen if you put the oil filter on without the gasket or with it? same concept. You should have noticed it missing before installing because its garbage after 1 use.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
'90 mustang will bad fuel pressure regulator cause idle surge? fords4me Mustang Problem Diagnosis 1 11-27-2009 02:18 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
