Old 12-23-2003, 08:38 PM
2of9 2of9 is offline
Summarize Crankwalk?
hello there fellow DSMers, i kno a little bit about this Crank-walk thingy in the DSMs, and i didnt get it very well from my studies. Can someone summarize crank-walk for me? thanks
Silver_GTR34
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-23-2003, 08:54 PM
NeonblueEclipse NeonblueEclipse is offline
Send a message via MSN to NeonblueEclipse
Re: Summarize Crankwalk?
engine dies all u need to know
lol
no really
crank walk is when the crankshaft starts "walking" meaning that it moves sided to side as it spins therefore damaging the bearings and causeing one hella a headache
usually crankwalk occurs with 2nd gen DSM's with the 7 bolt motor or the late first gens with the 7 bolt engine
the 6 bolt motors are usually fine, but every motor has potential for crankwalk
the wayz you kan check for crankwalk is check for play on your cranshaft and also theres your gas pedal sticks on the floor and i belive a knocking sound
correct me if im worng bout the symptoms
but i think thats how it goes
Dustin
GSX baby!!! ALL THA WAY
Old 12-23-2003, 10:41 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
it wouldnt be the gas pedal that sticks, its the clutch, cause when the crank is spinning and you push in the clutch if the crank is moving side to side it will be harder for the clutch plate to re-engauge while the crank is moving around!
now for a sumarization...
CW is not as common as everyone makes it out to be, it usually happens between 40-60k miles, yes it occationally happens after that but thats mostly when it happens. the reason the 7 bolt is more than the 6 bolt is mainly the oil system... 6 bolt has better and more oil points on the crank, 7 bolt does not. another thing that cause cause it is having a lot of power and a really good clutch = lauching! puting a lot of stress on the crank will jump and jerk making the crank put a lot of stress on the bearings (which is usually one of the first things to go out when CW happens then the crank starts to wear into the block, thats when your engine becomes fucked) also it is rare to see a 420a motor get crankwalk because it puts out less power due to it being a non-turbo, now in my case i am worried about that, so as of right now for my winter project i am ripping apart the block to cheak the bearings to make sure they arent wearing abnormally, and i will most likly replace then either way cause i think i am goin to get a stroker it! well i hope i answered your questions, and i am sure there are some other things that cause it but those are the only main ones i can think of right now, feel free to correct or add...
Jake
Old 12-23-2003, 11:10 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
There are so many bible-sized essays on Crankwalk that it isn't funny. If you don't get the info you were wondering about here, search some more.. there sure isn't a lack of info on it anymore.
Old 12-24-2003, 12:43 AM
DSMDAD DSMDAD is offline
crankwalk
go here for a good definition of crankwalk
http://members.shaw.ca/costall/1000...whatiscrankwalk
scroll down to the crankwalk section
Old 12-24-2003, 12:45 AM
crankwalk
sorry try this one
http://members.shaw.ca/costall/1000Q...hatiscrankwalk
Old 12-24-2003, 01:43 AM
kjewer1 kjewer1 is offline
AF - Advisor
Summary: The thrust bearing wears allowing the crank to move lognitudinally in the block.
The version with real info can be found at the RKO forums in my sig, as a sticky in the DSM section.
For some clarifications. No knocking sound, but there can be a clicking sound from the crank angl sensor killing itself. The car will usually be dead by the time you hear much of this. The carnk moves end to end, not side to side, unless the point of reference is the car and not the motor. The clutch pedal staying down has nothing to do with the crank sinning, or the plate engaging. Its because its easier for the plate to move hte crank to the drivers side of the car than push the pedal back up against the pedal assist spring. Takes some serious thrust bearing wear for this to happen. I wouldnt blame CW on the oiling system eiter. One possible, and perhaps likely cause, but there are far too many potential causes to blame any one of them. For example, 6 bolts walk too But 99.99% of the time, they are fine. Same oiling systems. Making a lot of power, or launching, doesnt affect cankwalk. The vast majority of the CWed cars are stock with stock clutches and old man drivers. Auto tranny cars walk just as frequently.
Everyone really should read that sticky on RKO. I had 3 motors crankwalk, and I've built a couple myself, so I like to think i know a thing or two about it. Unfortunate that it happened, but it was a learning expereince.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-02-2004, 02:16 AM
thanks guys...hahhaha
has anyone ever found a "CURE" for this CW??
--2OF9--
#808/1000
Old 01-02-2004, 02:22 AM
EclipseRST's Avatar
Banned
yea a new engine
Old 01-03-2004, 08:44 PM
will2shower will2shower is offline
Send a message via AIM to will2shower
OK, i am planning on rebuilding my engine in the fall. seriously though, replacing thrust bearings? new crank.. anyone know if this is a possibility?
Old 01-04-2004, 03:52 PM
GSX88 GSX88 is offline
It seams to me that replacing the thrust bearings should stop or at least slow down the onset of crankwalks. I know absoluty nothing on these engines so i wouldnt know for sure. And is there any way to increase the oil flow to the crank? like a better high flowing filter or a better pump? I want a gsx but my dad says they are shit.
Old 01-05-2004, 10:00 PM
don't listen to your dad.... gsx's are as sweet as they come, IMO but i think heard that removing balance shafts help with oil pressure..
Day 2 working on the Eg / GSR swap (One pic to summarize day) Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-15-2003 08:53 AM
