Old 12-23-2003, 08:00 PM
azee azee is offline
97 Blazer 4WD - 2WD indicator
The 2wd indicator on the electric shift no longer lights up, the 4wd light does and it goes out when I press the 2wd. I hear the transfer case shifting either way. How can I tell for sure that I'm not driving around in 4WD? Maybe it's just the bulb?
Thanks in advance.
Old 12-23-2003, 08:27 PM
ibhuff's Avatar
ibhuff ibhuff is offline
Re: 97 Blazer 4WD - 2WD indicator
If you can hear it shifting, chances are it is. Try replacing the bulb and see what happens. I dont know what else it could be.
Old 12-24-2003, 09:32 AM
Re: Re: 97 Blazer 4WD - 2WD indicator
The drive shaft going from the transfer case to the front axle always turns, even in 2WD, Is it supposed to?
Old 01-30-2004, 12:40 PM
nmaren nmaren is offline
I am having a similar problem - I have no power to my switch, and I cannot hear it shifting - any ideas? Mine is a 2002.
Old 01-30-2004, 12:46 PM
Woody B Woody B is offline
Thanks in advance.
It probably is your bulb, same thing happened to me.
Woody
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
Blazer 4wd works ONLY in Auto 4wd kayaker Problem Diagnosis 5 02-06-2008 05:49 PM
06 GV 4wd/2wd Question??? patrollingpaddy Vitara 0 07-16-2007 10:38 AM
4WD Light Indicator Problem 2000-Denali Yukon 2 11-11-2006 11:32 PM
4wd/2wd shifter fork (front axle) hiduke89 Cherokee 0 03-01-2005 12:50 PM
