Old 12-23-2003, 04:53 PM
estone4009 estone4009 is offline
Exclamation Coolant leak and random rough idle
1999 Silverado 5.3 L
After driving for 3 or 4 days the coolant leaks down to a particular level in the tank. No signs of coolant anywhere in engine compartment and none on ground, oil, etc. I have had a pressure test done on the coolant system and it holds pressure. Does not overheat and leaks down to a particular place on the tank everytime. Where should I check to see where the coolant is going? When I pull the spark plugs what exactly should all of them look like? The truck will randomly have a spurt of rough idiling that can't be traced down. The computer will randomly throw a P171 which is lean left bank on the exhaust sensor. Fuel pump and fuel regulator just replaced. Any ideas would help. Thanks.
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 11:46 AM
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
