Old 12-23-2003, 09:56 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
brakes
Sometimes when i hit my brakes they will squeal, this will only happen a third of the times i hit the brakes the other times it is fine. The noise is coming from the back. I checked the brake pads and they are fine, what could be causeing this? THANKS in advance.
For Sale 98 Eclipse GS, 5 spd
Old 12-23-2003, 09:05 PM
NeonblueEclipse NeonblueEclipse is offline
Send a message via MSN to NeonblueEclipse
Re: brakes
if there disks they may be dirty, or you might need a brake change
jus think it could be an opportunity to upgrade to a big brake kit lol
no sorry dude
i think its just the disks might be gone or jus dirty
Dustin
GSX baby!!! ALL THA WAY
Old 12-24-2003, 02:05 AM
kjewer1 kjewer1 is offline
AF - Advisor
ITs not uncoomon for pads to wear unevenly causing them to seat funny occassionaly. Also, rotors can develope spots of carbide from heat exposure that can catch the pads funny. As long as you are sure the pads are not excessively worn (i.e. you replaced them recently) I would just wait it out and see if it eventually goes away. If the pads are more than a year old or 20-30k miles, I would swap them out. They are cheap after all. You can even replace all 4 rotors for 100 bucks for parts store rotors. Brakes arent something to mess around with, but chances are it iwll be fine if the pads are good.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-24-2003, 07:41 AM
ashah000's Avatar
Thanks you guys. I took my car to a local brake shop to have them look at it and they said that the grease had worn off the pads. And they wanted $15 to regrease it HELL NO!!!!!! I took it back home and went to autozone bought some anti squeal grease and put some on the pad and it was prefect. But i probally will be replacing those pads real soon.
Old 12-24-2003, 07:19 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: brakes
good thing it wasn't that serious... to everybody else, a lot of places offer "free brake checks" and in my experience they most likely are, so if you are in question as to the solidity of your brakes, take it in and make sure you see them for yourself... most recently my fronts were so bad that small pieces were chunking off and lodging between the pad and rotor for a couple of seconds that "i think my tire is about to fall off" sound was eminating from my wheels... don't wait that long!!
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
Brake Booster replacement causes brake lights to stay on, and brake power is VERY low Ultranpthing Let's get Technical! 8 09-22-2005 05:15 PM
The Brakes the Brakes the Brakes are on Fire!!! Neutrino Street Racing 14 04-24-2004 02:29 PM
Brakes, Brakes Brakes hondaman-iac Accord/TSX/Accord Hybrid 0 08-11-2002 10:08 PM
