Airbag light flashes 6 times
The airbag light on my 90 Taurus has just started flashing 6 times, stops, and then repeats. Anyone have any idea what this error code means?
Do I have to be concerned about the airbag inflating, or is this an indication that a sensor is fried and the system is no longer functioning? Thanks for any help |
Code: Fault:
2 - All Primary Crash Sensors Disconnected. 3 - Air Bag Deployment Circuit - Low Battery Voltage or Low Backup Power Supply Voltage 4 - Safing Sensor - Diagnostic Circuit Open or Low Primary Crash Sensor Resistance 5 - Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground 6 - Driver-Side Air Bag Circuit - Open or High Resistance 7 - Passenger-Side Air Bag Circuit - Open or High Resistance 8 - Primary Crash Sensor - Not Mounted to Vehicle Properly 9 - Primary Crash Sensor Circuit - Open or High Resistance 10 - Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground |
Re: Airbag light flashes 6 times
Thanks for the info AutoSHO......now the search begins. Have also been told that the problem is likely the clockspring, this could explain the "Open Circuit"
I agree that it is the most likely culprit. Does your cruise control and horn work?
