Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-23-2003, 09:35 AM
timbo39 timbo39 is offline
Unhappy 1995 olds 88 - dies anytime
1995 olds 88 - runs good. dies at random under acceleration or idle speeds in gear or neutral....
check engine light does not come on until after the engine stops. the "battery" and "hot light" come on first and stay on until the problem clears. When those lights go out, it runs fine again. It seems to take about three tries to start before they go off. I replaced the O2 sensor, it was dirty, the engine runs better but still dies. What should I try next ? the crankshaft postion sensor, ignition module or the computer ? My older computer code tool does not fit the diagnostic port.
thank you for any help you can offer. Tim
Old 01-08-2004, 01:07 PM
back2life's Avatar
back2life back2life is offline
Re: 1995 olds 88 - dies anytime
does the vehicle have spark when it cuts off? if it does then most likely not the ignition module but still a possibility,try the crank sensor or combination sensor whichever it is called on your vehicle. this is a common problem on the 3800 it stops the spark also
Old 01-08-2004, 03:13 PM
Thumbs up problem solved, for now....
There seemed to be spark since it would re-start but would not run.
After replacing the computer, the problem is solved for the moment.
IFF the crankshaft or throttle sensors are going bad, the computer may not last as long as it should. I tried the computer because the problem was so intermittent but definitely would not run while in that condition.
I perfer problems that get worse making them simplier to diagnose. thank you for your thoughts. Tim
Old 01-08-2004, 03:51 PM
back2life's Avatar
so the vehicle is not cutting out nomore at the moment?if it is im pretty sure its the crank or combo sensor the same problems occured on my vehicle after replacing the ignition module .it ran fine till i drove for awhile then it would cut off with no warning no sputtering just cold turkey! as i couldnt find what it was i kept driving it and the time it would run got shorter and shorter.
Old 09-24-2004, 11:35 AM
iceman2 iceman2 is offline
You're losing fuel pressure, replace the fuel pressure regulator.
Old 09-26-2004, 06:41 PM
92-LS 92-LS is offline
You may also want to look at the Mass Airflow Sensor. It can tested with a gentle "tap" on the housing with the engine running. If it stalls, it's bad.
1995 olds 88 battery dies after sitting canyildiz76 Eighty Eight 8 07-19-2014 04:43 PM
1995 cavalier dies, and doesnt pick up speed ude_loose Cavalier Problem Diagnosis 2 03-10-2006 03:41 AM
1995 regal, died need help. drpepper13 Regal 1 09-16-2005 01:49 AM
1995 caravan died and wont start randy95 Caravan | Voyager 0 01-03-2004 10:52 PM
WTF!!!!!!!!! 74-year-old dies when......... ragt20 COMPLETELY off-topic 6 12-23-2002 10:54 AM
